Colour match help please
    Me again lol
    Satin green humbrol 131
    Signal red humbrol 174
    For my lynx hma8 build Royal Navy colours if this helps
    I'm looking for the equivalent in Tamiya or life colour .
    I've tried various colour conversion sites and no joy.
    Would xf 07 tamiya for signal red be acceptable once toned down with a satin sheen?
    Or
    Lc12 dark green with a satin coat?
    Any thoughts appreciated
    Daz
    Originally posted by \
    Me again lolSatin green humbrol 131
    Or
    Daz
    According to my andriod app
    131 = Mid Green Satin with no match
    174 = Signal red Satin = Velejo Model Air Ferrarri Red 71.085
    From The Vellejo Chart
    131 = 70.968 + 70.522
    174 = 70.909 + 70.522
    So, I assume its a matt colour plus a satin varnish on top
    Hope that helps
      According to my andriod app131 = Mid Green Satin with no match
      Hope that helps
      Thanks for that , you did better than me .
      I was hoping to go with Tamiya or life colour due to the fact I can get them localy.
      The postage charges are a nightmare but if needs must. At least I have the alternative as well.
      Daz
      • flyjoe180
        • Jan 2012
        • 12390
        • Joe
        • Earth
        These are not easy colours to convert. The best I can come up with for you is that Humbrol 131 'Mid Green Satin' could be related to Humbrol 101 'Mid Green Matt' which would equate to something like Tamiya XF05 (Tamiya use XF05 as a substitute for a lot of green shades however). Humbrol 174 Signal Red has no direct equivalent in either Tamiya nor the Life Colour ranges. XF07 Red with a satin coat may well be as close as you can get without going to another brand or getting the Humbrol paint itself.
          Hope that helps
          Hi, using your codes I've came up with Vermillion =Italian Red= Tamiya xf07
          Coool
          Now for green lol
          • Richi72
            • Sep 2013
            • 1100
            Hi maybe this is of some help
            LINK
            Cheers Richi
              For which component of the Lynx are the colours for Daz ?
              And what theatre is the Lynx being portrayed in ?
                Just add Daz that for the future try this. http://www.humbrol.com/converthumbrol
                Humbrol conversion for an umber of paints. Problem is that not all colours are convertible. Which is the hub of the problem. Airfix use Humbrol and the nearest paint to the ones they produce.
                What scale Lynx are you on ?
                  For which component of the Lynx are the colours for Daz ?And what theatre is the Lynx being portrayed in ?
                  www.britmodeller.com/forums/index.php?/topic/73386-westland-lynx-naval-versions/
                  Great link loads of pics
                  The green can be seen on both port and starboard side. Maybe floatation devices.
                  The red covers a multitude of areas and parts. I'd have assumed a very common colour used on many British milatry aircraft ect
                  I'm doing the folded tail version and collapsed rotors.
                  Ps 1:48
                    Hi maybe this is of some helpLINK
                    Cheers Richi
                    Hi Richie,
                    Yep same link I've used before , I think you need to put the name in sometimes or number and keep cross referencing other manufacturers until your lucy lol
                    The lead I got above helped me track down the red .
                    Daz
                    • Richi72
                      • Sep 2013
                      • 1100
                      Yep you are right with the cross referencing, but i think it is the most complete reference out there, at least I couldn't find another or similar.
                        I agree best one so far
