Are enamels better than acrylics for yellow propeller tips etc?
    I struggle to (brush) paint the small, fiddly bits in yellow or red acrylic. They take numerous coats before the colour is solid enough. I was wondering if enamels would give better coverage. It's really just for prop tips and the leading edges of wings etc. Maybe also red bits too.
  • Alan 45
    • Nov 2012
    • 9833
    I to have problems with yellow and I don't think it maters which you use ive found both have the same problem
    You just have to layer them until the part is completely covered I'm afraid
      • 18266
      Paint them white first. I don't think that one type of paint better than the other...
        Ian, do you mean a coat of white paint, followed by yellow? I hadn't considered that. I have some white primer in a spray can, which I would use for larger areas, but it would be a waste on 1/72 propeller tips.
          • 18266
          I normally prime the whole prop, white or grey, then give the tips a good white coat. Paint or primer it doesn't really matter. Primer might cover better....then I paint the yellow. Once that has cured I mask the tips off and paint the main colour of the prop. Remove the masking before the paint is dry, and you will loose the edge made by the tape...
          • stona
            • Jul 2008
            • 9889
            Same as Ian, except I prime the whole blade(s) white and so don't paint white before the yellow tips. You don't paint the yellow exactly to the tips as once masked the black (usually) of the blade will easily cover yellow.
            Yellow, as you've discovered, doesn't easily cover black !
            • stona
              • Jul 2008
              • 9889
              Also remember that the yellow tip was only FOUR inches (10.16 cm), measured from the tip of the blade, down the centre line of the blade.
              I see a lot of models with far too much yellow at the tips.
              1/32 the tip is only 3.175 mm (call it 3.2mm)
              1/48 the tip is 2.116 (call it 2.2mm)
              1/72 the tip is 1.411mm (call it 1.4)
                Here is a tip I got somewhere: put some yellow paint (I used yellow Vallejo Model Colour, an acrylic) in a small container, to a very shallow depth, and dip the end of something black into it, end first. If the length of yellow on the "part" is too small, add more paint. When the correct depth is reached, put the propeller blade into it, end first, and you will get consistent results.
                  Steve, is this formula for tip length/depth also to scale for helicopter rotor blades? I'm in the middle of a 1:72 Apache, so would it apply to the main and tail blades?
                  Thanks
                  Steve(!)
                  • flyjoe180
                    • Jan 2012
                    • 12390
                    • Joe
                    • Earth
                    The Apache in general does not feature coloured tips on the main rotors Steve, and you will need to research the scheme for the tail rotors depending on which air arm you are depicting.
                    [ATTACH]101259.IPB[/ATTACH]
                    • colin m
                      • 8741
                      • Colin
                      • Stafford, UK
                      All great advice above. I would add, I've noticed sometimes my yellow tips are too yellow. I prefer a slightly faded look.
                        This is where filters are useful. They tone down colours and blend them to reduce too bright an effect or too stark a contrast. If you apply a suitable filter to the entire prop after it has been painted and transfers applied etc. then you will find it looks more realistic.
                          Enamel or acrylic, yellow is a very tricky colour. It's mainly down to the fact that yellow pigments are, by their nature, very transparent, hence the need to undercoat in White or light grey. But its also that toning it down is incredibly difficult, as a tiny amount of any other pigment turns it into ochre or worse in an instant! When an artist, I had a pot of brushes purely for yellow (I kid you not, however well you clean a brush, traces of previous colours will remain, not a problem, on the whole, but with yellow it's a no-no). Richard speaks the truth, best to tone it back with a fine filter, or experiment with grey undercoats!
                            [ATTACH]111234[/ATTACH]
                            Thanks Joe, I believe the British Army Air Corp WAH Mk1 does have yellow tips, or at least has done in photos I've seen of them in repair. I'll do some more research, but thank you for the heads up.
                            • colin m
                              • 8741
                              • Colin
                              • Stafford, UK
                              Not something I've used Richard, but does sound interesting. Any suggestions ?
