Halfords Grey Primer —heads up
  • yak face
    • Jun 2009
    • 13860
    • Tony
    Just a quick heads up to anyone who uses Halfords grey primer from the rattle can . Its something I use a lot for the priming of my models and has always performed flawlessly - giving a smooth uniform finish ,hardwearing , great adhesion of subsequent colour coats etc BUT —- I got a new can the other day and noticed the can design has changed , and on using it seems the formulation has also changed .First thing I noticed was the colour is a lot lighter , also it smelt very strongly like an acetone type solvent and went on very wet . I panicked that it might start eating into the plastic ( the old acrylic formulation was perfectly benign ) so stopped spraying straight away .
    I then got a part of a kit from the spares box and sprayed it on quite thickly to test if it would attack the plastic . It looked very thick and wet and when I scratched at it the surface of the plastic did look to have softened . The parts I didnt scratch dried back quite well and seemed to be very hardwearing but I’m not going to risk using it just in case . Why is it that whenever we have something thats perfect for the job they have to go and change it !
    heres a pic of the new orange design tin alongside the old one . Click image for larger version
  • Neil Merryweather
    • Dec 2018
    • 5202
    • London
    Yup I had the same experience grrr. And it's not very matt either. I'm switching to Hycote, which you can get from Wilko for £5.99 at the moment!
    • PaulTRose
      • Jun 2013
      • 6526
      • Tattooine
      I think its called 'progress' or 'new and improved' ??
      Ive used a cheapo brand from Boyes for years and no problems
      Per Ardua
      • yak face
        • Jun 2009
        • 13860
        • Tony
        Yes , if you mean the Auto Tek one Ive used that too paul , think its going to be my number one choice now .
