Spraying Vallejo Matt/Gloss Varnish?
  • Adrian "Marvel" Reynolds
    • Apr 2012
    • 3008
    #16
    Have a question regarding my use of Vallejo Gloss again,,,,,
    I sprayed the fuel pods on my F-4C and left the paint 2 days, then varnished them with Vallejo Gloss. Left that a day then masked it up to lay down the green camo on the tops of the pods.
    Once this was dry about 20 mins I started to remove the tape, to find it also peeled off the gloss varnish in areas along the fuel pods.
    Can anyone suggest what I may be doing wrong?
    Adrian
    • Gern
      • 9220
      #17
      Just to add to the confusion. It says on my bottle of Vallejo Matt varnish that I can thin it with water.
      • tr1ckey66
        • Mar 2009
        • 3592
        #18
        Hi Adrian
        Yes you can thin vallejo varnish with their thinners. I do it all the time. Another tip is to put a ball bearing in the bottle to aid mixing.
        Hope this helps you get the results you're after.
        P
          Originally posted by \
          The answer is no then Adrian. Tamiya is not water based cannot remember its thinners.
          Yeah it's isopropanol you need for Tamiya but really Tamiya thinners may be the best thing. It's water based as in not oil based but don't thin with water
            Hi Adrian
            P
            I've seen how long it takes to fully mix Vallejo... You think it's done, but it's not haha it really takes forever
              • Apr 2012
              • 3008
              #21
              I sorted the spraying part out by thinning it with Vallejo Airbrush thinner,,, but its the issue of it coming away with the Tamiya masking tape I could use some advice on .
              Adrian
              • tr1ckey66
                • Mar 2009
                • 3592
                #22
                Oh, sorry Adrian. I've never experienced that problem.
                Are you giving the varnish enough time to cure properly - 24hrs?
                To be honest by the time I'm applying the varnish the masking part is pretty much done.
                The vallejo varnishes seem pretty resilient to me so i can only guess at the drying times, or perhaps that is what thinned too much?
                I hope you resolve the issue though.
                P
                  Which Vallejo Gloss are you using Adrian.
                  Is it Acrylic 26.157 or Acrylic Polyurethene 62.064. You are better off with the Poly. It doe not need any mixing shaking although it says shake it. It is the virtually consistency of water. It provides, I have found, a better finish. But it does take a little longer to cure but cured it is much tougher than the the acrylic and gives a higher gloss.
                  Not had to thin the Poly at all. Just wonder Adrian if the Vallejo does not like Tamiya to stick to. Do Tamiya do a gloss ?
                    • Apr 2012
                    • 3008
                    #24
                    It's the Poly 26.650, its most certainly not as thin as water though it does say it can be sprayed straight from the bottle. I tried that and just got a blocked needle everytime ( .35 size )
                    If I mix it with Vallejo Airbrush thinners it sprays perfectly and the shine is great.
                    Like you say I should try to find a low tack tape
                    Adrian
                      Adrian try these. I rarely use Tamiya tape after finding these.
                      3M Fine Lining Tape Blue. Bit tougher and slightly better seal
                      Fine Spray Lining Tape. Very easy release and going around corners.
                      Both are available in a number widths. Also easy to slice a thin piece.
                      This first picture gives an idea of the crisp clean lines and also the versatility of these tapes.
                      Also use the green as it more flexible for canopies.
                      [ATTACH]116654.IPB[/ATTACH]
                      Both seal better than Tamiya. Both stretch [ATTACH]116651.IPB[/ATTACH]
                      [ATTACH]116652.IPB[/ATTACH]
                      [ATTACH]116653.IPB[/ATTACH]
                      [ATTACH]116650.IPB[/ATTACH]
                      • rickoshea52
                        • Dec 2011
                        • 4076
                        • Rick
                        #26
                        [ATTACH]128004[/ATTACH]
                        Both seal better than Tamiya. Both stretch [ATTACH]128001[/ATTACH] [ATTACH]128002[/ATTACH] [ATTACH]128003[/ATTACH]
                        Where do you get that stuff from Laurie?
                          The question regarding using water based thinners with Tamiya paints wasn't posed Laurie, if you read Adrians posts.
                          Whilst I'd never advise using Vallejo thinners with Tamiya paints, many people have thinned Tamiya with water & say it works ok( not something I'd do!)
                          Hi guys I thin all my tamiya paints with ipa it's cheaper than x20a and I can't tell the difference maybe it cures a but quicker all I would say is experiment on a scrap model just my thoughts
                            If you have a local body shop supplier Rick they should have it. These are on Ebay. Tried Amazon but they have few contacts.
                            Funny one on the first one below in Ebay. One tape ยฃ1113:95. Even funnier that there are two watching.
                            http://www.ebay.co.uk/sch/i.html?_odkw=3m+fine+lining+tape&_osacat=0&_from=R 40&_trksid=p2045573.m570.l1313.TR1.TRC0.A0.H0.Xfin e+spray+lining+tape.TRS0&_nkw=fine+spray+lining+ta pe&_sacat=0
                            http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=m570.l1313.TR0.TRC0.H0.X3 m+fine+lining+tape.TRS0&_nkw=3m+fine+lining+tape&_ sacat=0
                            One thing I forgot. Keep in a plastic bag or the edges will pick up dirt and bits. Nuisance but then the advantage is that the edges are sticky and give a good seal.
                              • Apr 2012
                              • 3008
                              #29
                              Thanks Laurie,
                              I was actually looking at getting some of this tape, thanks for the link to them
                              Adrian
                                What's the smallest width that the 3M tape comes in?
                                3mm is the smallest I can find, I guess your cutting it down by hand Laurie?
                                Is there any difference between the green and blue types?
