Help clear gloss gone white
    I need some advice. I have painted my bismark hull and let it dry for over a week .I put a clear gloss coating on this morning and have just gone back to it and it has got white flexs all over it any ideas of what has happened and how to fix it thanks.
  • Dave Jay
    • Oct 2015
    • 543
    Sorry to hear about your plight, what clear gloss was it and what did you thin it with and was there any dampness in the air when you painted it?
      Yes hi it is humbrol clear gloss and it was thined with water and it was a bit damp in the air .
      • Paul Davies
        • Apr 2014
        • 284
        I have stopped using humbrol paints as I have found the quality has gone downhill. I recently used gloss spray can and it came out matt finish
          Cold at night with temperatures down over night at the weekend. Fog next day. I would bet it is that
          high humidity and record temperatures from the sun pouring down all day. all taking up a mass of
          moisture in the air. as the temperature the air can not support all that moisture and it condenses
          on any surface which is cold.
          Used to have the same when I built in the garage Phil. Used to have a plant propogator which I put
          painted parts in.
          Cannot help with fixing it. I suspect the gloss coating has separated. i take it it has not shown improvement
          at all. guessing it may be moisture within the clear coating if so gentle heat may cure it.
            painted parts in.
            Thanks I will give that a go
            • rickoshea52
              • Dec 2011
              • 4076
              • Rick
              Humbrol Clear? Hmmm. I've had the same problem which is why I've relegated it to canopies and cockpit transfers. I have gone back to Railmatch acrylic varnish.
                Was it Humbrol "Clear" which is different from Humbrol Gloss Varnish.
                What problems have you had Rick ?. Worked perfectly for me in all ways. Works well airbrushing and is very resilient to use. Easy to clean the airbrush which is not for many varnishes.
                If it was Humbrol Clear mixing with water as Phil has stated and it was Humbrol Clear as opposed to Humbrol, that may be the problem. Humbrol Clear is so thin you do not need to thin.
                • dave
                  • Nov 2012
                  • 1828
                  • Brussels
                  Humbrol Clear has always worked well for me.
                  Recently tried the Humbrol Clear Matt and that looked like the model had been sprayed with white paint, going to have to do a little experimentation with it to try different conditions.
                  • rickoshea52
                    • Dec 2011
                    • 4076
                    • Rick
                    This stuff....I don't rate it.
                    [ATTACH]123945.IPB[/ATTACH]
                      Isnt humbrol clear a enamol/oil based product? Perhaps its the water thats caused it?
                        No, it's an acrylic & is cleaned with water. I've never had any problems with it.
                        Usually it's a matt coat that can display a white ' bloom ' - I've never heard of gloss products doing it.
                        However, the ' white flecks ' sound more like dust particles or some other contaminant in the Clear, rather than humidity / airborne moisture problems.
                          Humbrol Clear Dave is water soluble.
                            Actually chaps we do not know what Humbrol product we are talking about.
                            Phil is it Humbrol "Clear" or another of their varnish products ?
                            • colin m
                              • 8740
                              • Colin
                              • Stafford, UK
                              Same here. I've had Vallejo matt varnish produce little white spots all over the place - getting tired of Vallejo..........
