Natural metal finishes and varnish?
  • stona
    • Jul 2008
    • 9889
    #16
    Agree with the above, I give a final polish with some denim material (of unknown but extremely high grit value )
      • 22771
      #17
      Originally posted by \
      Hi Ian
      I ordered some stuff from John, the gloss black primer ( metal coat ) metal steel and aluminium and the gloss varnish ( all metal coat)
      I have 1200 grit pads so I'll give the Mig a good ol rubbing first. I'll also do the same for the J10 but that's got ghost camo going on so the primer wil be normal Val black.
      I'm hoping for a smooth NMF on the Mig and il try and dull down a bit on panneling And rivot detail
      Hope it pans out
      Regards
      Robert
      Hi Robert I would go with the others and get some finer sanding paper but the primer and paint are what you need good luck with it and I would do a little practice piece first just to see how it works with it being a very thin paint you will use a lot or flood the area very quickly if your not careful.
      • Robert1968
        • Mar 2015
        • 3596
        #18
        Hi Ian
        I'm thinking of passing lightly over when I spray and from a distance ( got the wife on the saving the plastic milk bottles)
        What a better grade than 1200 ( as I thought that was polishing grit
        Your advice like any other is invaluable
        Regards
        Robert
          • 22771
          #19
          I do use up to 1200 just like the ones you've got but give them a sanding/ polish with 2000 then 10000 polishing sponge
