paint conversion helpers...
    • 18255
    Seems like a lot of us need help cross matching colours between brands, so this thread is hopefully here to help.
    If you find a link to a good site with conversion tables, post it in this thread so we can find them easily.
    Here are a couple to start the ball rolling;
    www.paint4models.com/paintchart/paintconversionchart20100101g.html#
    Covers most of the popular hobby brands and has a search function!!! (I use this one a lot.)
    www.ipmsstockholm.org/colorcharts/colorcharts.asp
    I find this one quite helpful as well.
    www.acrylicosvallejo.com/en_US/downloads
    loads of info on their paints, a good FAQ and each of the files on the different paints has a list over conversions. They can be downloaded.
    Dont expect the colours shown on the screen or if you print the folders out to be 100% (unless you have a fully calibrated screen and printer). But good enough to see sort of where they lay.
    Any more out there?
    www.creativemodels.co.uk/paint_conversion.php?manufacturers_id=8
    • dave
      • Nov 2012
      • 1828
      • Brussels
      There is also an app available iModelkit which is very useful, despite the initial letter I do not think it is limited to apple.
      • monica
        • Oct 2013
        • 15169
        very useful all,thank you for posting this one,
        but still that lifecolor is a hard one to track down to cross with other brands,
          There's hobby colour converter and model assistant apps on Android too.
            These are some I use.
            www.humbrol.com/us-en/converthumbrol
            downloads.hobbico.com/misc/rmx/TES_Revell_Paint_Match_Guide.pdf
            scalemodeldb.com/paintcharts/modelmaster
            Of real use is www.cybermodeler.com/aircraft/h-3/h-3_profile02.shtml
            This in most cases give aircraft colours in official terms. Also walk abouts and many other itmes for help in model making facts.
            • monica
              • Oct 2013
              • 15169
              ta for the info, this will be of some help,
                a helpful app I found is Hobby colour converter for android think you can get it for apple as well
                • BarryW
                  • Jul 2011
                  • 6006
                  I have to say that I do not use conversion charts.  I will research the correct colour for the build on-line and select the appropriate colour from the range I am using.  FS, RLM and BS numbers are all useful guides and some paint ranges supply these for easy reference.
                  The most useful chart is this one also identified by Ian: http://www.ipmsstockholm.org/colorch...olorcharts.asp
                  other useful ones I have not spotted above:
                  Aircraft illustration - side views, combat paintings and civil aircraft promotional / publishing work. Prints can be ordered directly from this site or commissions can be taken.
                  • zuludog
                    • Mar 2015
                    • 239
                    This site has conversion charts from several paint ranges to current Humbrol colours
                    Then you can use that on other charts to get to various other ranges
                    The site is useful for returnees who might have stocks of old enamel paints as it gives conversions from Airfix, Heller, and Humbrol Authentics to current Humbrol
                    www.scaleworld.info/page2
                    Go to their home page and there sections on other aspects of modelling
                    • AlanG
                      • 6296
                      Anyone else having problems with the paint4models chart not working? I've tried on the phone and pc and it isn't loading
                      • Gary MacKenzie
                        SMF Supporter
                        • 1057
                        • Gary
                        • Forres , Moray , Scotland
                        If using chrome make sure you click on the I in a circle in front of the address and enable flash for the site
                        If flash is disabled you get a blank page
                        If using firefox check if flash is disabled
                        • AlanG
                          • 6296
                          I've been trying to access the ipms colour chart (and site)for a while now and all i get is a 500 - internal server error. Any ideas guys n gals?
                          • Gary MacKenzie
                            SMF Supporter
                            • 1057
                            • Gary
                            The whole server is returning a 500 error ... i.e. server is not working properly.
                              I'll just chime in here to mention a paint conversion site I made recently called ModelShade www.modelshade.com. Plug over.
