I just bought the Vallejo Luftwaffe Colours 1941 to end-war kit with 8 colours in order to build and paint some airplanes because Tamiya hasn't got RLM colours. Not the ones I wan't.
My go to masking tape is 3M Scotch Purple which is their lowest of low tack masking tape (and a very expensive one too) and it's never ever failed me before so you can guess how happy I just was when I uncovered this...
[ATTACH]291170[/ATTACH]
[ATTACH]291171[/ATTACH]
I will probably be able to repair it but it lifted the paint on the bottom side too and that was painted over 30 hours ago and was bone dry!?!
Do you have to put a clear coat on Vallejo Air before using masking tape or do you have to use some magic Vallejo specific masking tape in order for it to work???
Every time I try using anything but Tamiya paints there's always something that goes wrong and I just don't see the point of having paints that doesn't bond to the primer or other layers of paint!
The model was squeaky clean before painting and the paint was thinned with Vallejo thinner so no foul play on that part either.
It's a shame because the colours look really good - apart from it falling off that is...
