Problem with Stynylrez primer
  • Mr Bowcat
    SMF OG
    • Dec 2016
    • 4597
    • Bob
    • London
    Morning guys,
    I was priming some bits last night with Stynlrez grey (my go to primer). I was shooting it from a .4 needle at around 25 psi as usual. Normally this setup works fine, however last night I was having loads of issues, it wasn't spraying nicely at all, constantly clogging and drying on the tip of the needle.
    I'm near the end of the bottle and I'm wondering if it thickens up as it runs out/ages? If so, is it worth trying to thin it or should I just bin it and buy another? I was going to order a large bottle form John (currently got the smaller bottle), but if it does have a tenedency to go off I might just stick to the small.
    Any advice gratefully appreciated.
    B
    Si vis pacem, para bellum.
    Hi Bob, I use the same primer. I've had the large bottle now for 14 months and had no issues. I do shake the living life out of it before use as you can clearly see how it settles in the bottle.
    Once had tip issues and I found that my comp moisture trap was rather full allowing water to enter the airbrush and mix with the primer.
    • Mr Bowcat
      SMF OG
      • Dec 2016
      • 4597
      • Bob
      • London
      Thanks Alan. I have a stainless steel ball in the bottle and did give it a good shake, and had only started airbrushing so no moisture build up. I'm really not sure why it behaved so differently than normal?? I'll try again tonight and really shake the hell out of it.
      • BarryW
        • Jul 2011
        • 6010
        It can thicken over time as I found. It is also very important to strip clean the airbrush after use. It does gum things up worse than base paint.
        • Mr Bowcat
          SMF OG
          • Dec 2016
          • 4597
          • Bob
          • London
          Cheers Barry.
          Yes, I do give it a full strip after using the primer, as you say it likes to stick fast to eveything. Anything I can do about thinning it, or is best to chuck it and buy another?
          • BarryW
            • Jul 2011
            • 6010
            I used Vallejo Airbrush Thinner - it works just as well with Stynyrez as with VMA. Water should work though I do think the thinner is the better route.
            • Mr Bowcat
              SMF OG
              • Dec 2016
              • 4597
              • Bob
              • London
              Ive only got IPA or X-20, any idea if either would work?
              I guess I should probably try on some scrap styrene with each and see which works better.
              • meggsy
                • Jun 2011
                • 421
                Rightly or wrongly I've thinned it with IPA with no problems
                • Mr Bowcat
                  SMF OG
                  • Dec 2016
                  • 4597
                  • Bob
                  • London
                  Thanks for that Steve, IPA it is. :smiling3:
                  Edited to add, what sort of ratio do you use?
                  • meggsy
                    • Jun 2011
                    • 421
                    I've no rule of thumb just till it flows easier probably 30% IPA to 70% primer
                    • Mr Bowcat
                      SMF OG
                      • Dec 2016
                      • 4597
                      • Bob
                      • London
                      Cool, cheers.
                        I'd be tempted to add a little flow-improver and retarder to the mix (and hey presto, you've made your own thinners!) Although Stynylrez works fine out of the bottle, thinning it thus will not affect its greatness, just make it a little more tolerant! You'll still get that super smooth finish.
                        • Mr Bowcat
                          SMF OG
                          • Dec 2016
                          • 4597
                          • Bob
                          • London
                          Thanks John.
                          I did try it with a little IPA last night and it was defintiely better. Having said that, there's probably less than 10% left in the bottle, so when my order from John arrives later today I will probably bin it.
                          • colin m
                            • 8740
                            • Colin
                            • Stafford, UK
                            I use the same stuff, but leave the bottle on its side. Once in a while, like when I remember, I rotate the bottle 180 degrees. This strange ritual, I hope, stops the primer settling too much.
                            • Mr Bowcat
                              SMF OG
                              • Dec 2016
                              • 4597
                              • Bob
                              • London
                              Thats not a bad idea, maybe just give it a shake every week.
