Varnish Gloss help
  • slupanter
    • Jun 2010
    • 554
    Varnish Gloss help
    Hi
    What is causing this surface?
  • Wouter
    • 742
    you mean the orange peel finish? Depending on the paint/varnish used this is normal. Look at modern day cars, they all have it some way or another. Most modern day 'environmental friendly' waterbased paints have this, it's inherit to the paints. Unless you used a solvent based varnish, then I really don't have a clue.
    • slupanter
      • Jun 2010
      • 554
      Hi Wouter
      I am using Tamiya paint with Mr Hobby B-513
        • 18908
        Hi Alexander
        I’d say spraying from too far away and/or at too high a pressure. The varnish needs to flow out a little before the solvent flashes off. In this case the varnish has dried almost instantly on hitting the surface.
        • slupanter
          • Jun 2010
          • 554
          Hi Alexander
          It's from a rattle can. Everyone else seems to get great finish with Mr Hobby varnish
            • 18908
            Could still be applied from too far away, or perhaps not enough varnish on the surface. Another point, is the can properly mixed? If you want a high gloss finish let it gas off for a few days then polish it with Tamiya polishing compound or similar to flatten the surface and bring out the gloss.
            • slupanter
              • Jun 2010
              • 554
              Thanks, i am glossing to apply pin washes.
              I think i need to test spraying closers and wet sparying. I'll keep you posted
                • 18908
                That finish will be fine for a pin wash, the subsequent Matt varnish will hide the surface imperfections nicely.
                • slupanter
                  • Jun 2010
                  • 554
                  Thanks for the guidance Tim. Save me binning a project
                    • 18908
                    Never bin anything Alexander, getting to the end is part of the learning curve. You may have to work around a problem, or rethink the end point, or even on very rare occasions strip the finish and try again, but you will learn something every time. Let’s face it, If everything worked great first time we might as well be painting by numbers LOL.....
                      You seem to be implying we’re not …
                      • slupanter
                        • Jun 2010
                        • 554
                        Hey all!
                        Update time. I have found Mr Hobby gloss and matte do the job really nicely, so thank you all for your help.
