Base coat for metallics.
  • outrunner
    • Apr 2019
    • 2420
    I have had a search through the paint forums but not seen anything about what would be the best base coat/primer for acrylic metallic paint. Sorry to be a pain, but does anyone know if I need something other than basic primer?
    Andy.
  • AlanG
    • 6296
    I am just doing a P-38 build in NMF. I am using Vallejo Metal Colour Surface Primer and the Metallic paints.
    Link can be found below in my signature
    • outrunner
      • Apr 2019
      • 2420
      Thanks for that, nice job on the P 38. At the moment the only paints I have are Tamiya but I may look at Vallejo as the finish on your mode; looks really good.
      Andy.
      • AlanG
        • 6296
        Cheers Andy.
        I originally bought the Tamiya Metal paints but i don't like the finish on them. But that is my own personal preference. Some will also recommend AK Metal paints. I haven't used them though. The Vallejo Metal paints are enough for me. Plus you can brush paint them too which is great for small items
        • slupanter
          • Jun 2010
          • 554
          MRP all day, their black gloss base is brilliant and sprays like a dream.
          All of their metals are extremely realistic and again spray like dream
            Andy,
            I use gloss black as a base for metallics, but any paint that gives a smooth blemish free finish should be fine
            • outrunner
              • Apr 2019
              • 2420
              Thanks for that Dave, should I use primer first then the gloss black? As you can see I am new to all this painting stuff, more used to iron on coverings with RC model aircraft and have not done much in the way of paint for about 30 years so no doubt there will be more questions to come.
              Andy.
              • AlanG
                • 6296
                Andy
                The Vallejo Surface Primer is a gloss black
                  • 15669
                  I agree with Dave and Alan. A gloss black primer. Vallejo metal color primer is gloss black. It is acrylic and should provide a nice base for a metallic top coat. I actually rather like the Vallejo metal color range. Ok not up to the level of lacquer metallics but pretty good.
                    Andy,
                    the secret of a good metallic finish - is to have a blemish free, oil free surface to apply it to. The slightest blemish, bad seam, mismatch will stand out like a sore thumb! I generally give a light primer coat ( std primer ), which will show up any problems - which should be dealt with before moving onto the black gloss base. Let the basecoat thoroughly dry - 24hrs at least, before applying the metallic!
                    • slupanter
                      • Jun 2010
                      • 554
                      Vallejo primers are a waste of money, get some stynylrez black gloss primer
