Mr Color / MRP / Tamiya - cleaning question
    I am considering options beyond Vallejo and can find no decent information online, so I thought I’d try and tap in to your collective experience. Apologies if this is a duplicate thread; I’m on the road and using my phone.
    My question is this: what do you use to clean the following?
    Mr Color
    MRP
    Tamiya
    I would always use the matching branded thinning medium and my only concern is keeping the airbrush clean.
    Thanks!
  • Mr Bowcat
    SMF OG
    • Dec 2016
    • 4600
    • Bob
    • London
    IPA to clean all of those.
    Si vis pacem, para bellum.
      Easy peasy!
      Thankyou.
        For Mr Color I use cheap cellulose/lacquer thinner. I hear it's very good for MRP too.
          I’m still in two minds. The main issue is the flammable, hazardous nature of the things.
          I pretty much only use three colours (white, sky & EDSG) so might be worth trialling with the first that runs out.
            • 18903
            I use Mr levelling thinner....same as I use to dilute the paint.
              This occurred to me, but isn’t using thinner more expensive than IPA / cellulose?
              • BattleshipBob
                • 6792
                • Bob
                • Cardiff
                Liquid reamer, recommended by the airbrush tech at the airbrush company, works very well
                  • 18903
                  Yes, but I do’t spray often enough to think it’s an issue. I only use a few mL to clean through the brush, then strip the brush and use a few more mL to wipe down the needle, clean through the nozzle, and clean the cup and brush.
                    Excellent point.
                    • Bortig the Viking
                      • Mar 2019
                      • 780
                      Hi, which one do you use ?
                      • BattleshipBob
                        • 6792
                        • Bob
                        • Cardiff
                        Its Premi air
                        • Bortig the Viking
                          • Mar 2019
                          • 780
                          Its Premi air
                          Ah, John sells that. Might get some.
                          • Mr Bowcat
                            SMF OG
                            • Dec 2016
                            • 4600
                            • Bob
                            • London
                            Not wanting to put John out of a sale, but IPA is cheap, £18 a gallon. https://www.amazon.co.uk/ISOPROPANOL...2104236&sr=8-4
                            I've not found a model paint yet that it won't clean.
                            • BarryW
                              • Jul 2011
                              • 6010
                              With MRP I use i.p.a. mostly with the benefit that it is cheap bought in bulk (but store it safely...)
                              I also use Mr Tool Cleaner as it is stronger than i.p.a. and lacquer thinners. I don't use it all the time, only if I think it needs some extra cleaning power or when I do a full strip clean at the end of a project. https://www.scalemodelshop.co.uk/pro...mr-hobby-t-116
                              I have not tried it but you can get bulk purchases of lacquer cleaner from hardware shops or on-line that can clean just about anything, strong stuff.
                              One word of warning - make sure your airbrush seals are solvent proof before using Mr Tool cleaner of lacquer cleaner.
