Vallejo Model Air metallics
  • Mr Bowcat
    SMF OG
    • Dec 2016
    • 4600
    • Bob
    • London
    Hi guys,
    I found a bottle of Model Air brass in my paint drawer, I think I bought it to do the bolt heads on the inside of a Bradley a couple of years ago. I want to try airbrushing it but never used this brand for spraying before. What do I need to know regarding thinning it to airbrush?
    B
    Si vis pacem, para bellum.
  • Jack L
    • Jul 2018
    • 1270
    • Cheltenham
    I have always found Model Air airbrushes well straight from the bottle, and can obviously be thinned further to suit. Admittedly I have not got any metallic colours from them I don't think.
      • 22770
      I spray mine straight from the bottle Bob, no need to thin at all.
      • Mr Bowcat
        SMF OG
        • Dec 2016
        • 4600
        • Bob
        • London
        Thanks for the quick responses gents, will give it a go neat from the bottle.
        Out of interest, if I did need to thin it, what would I use?
          • 22770
          Originally posted by Mr Bowcat
          Thanks for the quick responses gents, will give it a go neat from the bottle. :smiling3:
          I use Tamiya thinners, only because that's what I've got. works a treat. you could also use there own brand.
          • Jack L
            • Jul 2018
            • 1270
            • Cheltenham
            I have the Vallejo Airbrush Thinner.
            • Mr Bowcat
              SMF OG
              • Dec 2016
              • 4600
              • Bob
              • London
              Cheers gents. I don't have or want to buy Vallejo thinner as this is a one of use of their paint.
              Ian, is it the X-20A thinner you use? I have plenty of that.
              • Jack L
                • Jul 2018
                • 1270
                • Cheltenham
                Ian, is it the X-20A thinner you use? I have plenty of that. :smiling3:
                Yeah it pains me to buy the different brands to suit, just don't use Mr Levelling Thinner...turns my Vallejo to gloop.
                  • 22770
                  Yes it is Bob.
                  • Mr Bowcat
                    SMF OG
                    • Dec 2016
                    • 4600
                    • Bob
                    • London
                    Thanks guys.
                    • stillp
                      • 8090
                      • Pete
                      • Rugby
                      IPA works too.
                      • BarryW
                        • Jul 2011
                        • 6010
                        Check your needle size. It works best with a .3 or larger needle. .2 works but for that thin the paint a little with Vallejo Thinner. It does not work well with smaller needle sizes.
                        • Mr Bowcat
                          SMF OG
                          • Dec 2016
                          • 4600
                          • Bob
                          • London
                          Thanks for all the advice gents, it sprayed fine neat through a .4 nozzle.
                          One more quick question, how long does it need to dry before masking?
                          • BarryW
                            • Jul 2011
                            • 6010
                            Ideally in an airing cupboard for 24 hours and prime first on washed plastic.
                            • Mr Bowcat
                              SMF OG
                              • Dec 2016
                              • 4600
                              • Bob
                              • London
                              Thanks Barry.
                              I'd cleaned the parts with IPA before priming with Mr Surfacer 1500. From that point they were only handled with gloves on so hopefully I should have avoided getting finger oil on them. I sprayed the Vallejo last night so will wait until tomorrow before masking to be on the safe side.
