Hi all
So time time stick my head above the parapet again.......
I hope this doesn't come across as me trying to teach some very experienced modellers to suck the proverbial egg......but I've been in a PM conversation with Comrade Dzhon "4BO" Race about this recently and he thought it be might worth sharing with you.
I've noticed a number of you moving to AK 3rd Gen paints from Vallejo (and other water based acrylics). I'm not saying what I have to say will make that stop but at least it might help use up those old stocks of Vallejo with a little less frustration, for not much of an outlay. It may of course help those of you persisting with Vallejo, despite the dry tip issues we often encounter.
Anyway enough waffle........
When I first came back to the hobby I was lucky and had some very good advice from someone on another forum. He sent me an old airbrush and other supplies to get me started.
One thing he sent me was a bottle of DecoArt Americana Drying Time Extender Medium (see below). Although the bottle's always been there, I've kind of forgotten about it and the advice my friend gave me. I have recently 'rediscovered it', having just re-read the guidance he sent me during a clear out- he was an absolute genius with an AB BTW.
His advice to me was as follows:
It may be my eyes but this results in a mixture that seems noticeably more 'fluid' than if using one drop of Vallejo's own flow aid to the same ratio but not thin, if you get what I mean?
I used it when painting my Pz II and I have to say that experience was a vast improvement over previous sessions - and I had a lot of tank to cover. If not completely eliminating dry tip, it wasn't far off doing so.
Dzhon has also recently given it go and from what he said, his limited testing with some white Vallejo primer went well.
Price wise it was £2.60 for a 59ml bottle (4.4p per ml + p&p) from HERE. By comparison John is selling Model Air at £2.55 for 17ml (15p per ml + p&p). So, even if it doesn't work out for you it's not a big waste of money. I've not tried with any other paint but I'd like to think it will work with other water based acrylics.....
Anyway, as I said at the start I'm not trying to teach any of you to suck eggs but I thought I'd bring it to your attention in case it helps some of you, especially those members that are newer to the hobby and are just starting out on their airbrush journeys.
All the best.
Image courtesy of Comrade Race (all rights reserved).
- 2 drops of flow aid in the bottle upon arrival;
- in the AB cup,1 drop of the medium for every five of paint (not 1:1 as the bottle says);
- then, if necessary, additional thinner to get the paint to the right consistency;
- but no more flow aid if you use that as it is already in the paint mix.
All the best.
