Brush vs airbrush?
  • The Smythe Meister
    • Jan 2019
    • 6248
    #106
    Tim,
    As I recall, in Japanese culture the imperfection is part of the perfection - hence high quality porcelain would have a flaw deliberately incorporated! That actually forms a rationale for my failed efforts!
    Blimey Steve.......
    .....by that train of thinking....... i`m an absolute GENIOUS !!
    • BarryW
      • Jul 2011
      • 6010
      #107
      It’s your lungs Barry, but I would read up on the MSDS before exposing them like that. If your glasses are steaming up your mask doesn’t fit properly, or is not fit for purpose. I would strongly suggest you source a better quality mask before you do your lungs and organs irreparable damage.
      I have had at least half-dozen different types of mask and I have not had one fit well.
      Don't get me wrong, I know there is a problem and that is why I spent more than most on an expensive high quality venting spray booth with a good 'draw'.
      I also will still, most of the time, wear a mask while spraying primer or if spraying for more than a few minutes, even though it is very frustrating trying to cope with it. Most of my spray sessions are over within 5 minutes.
      I have tried a lot of different ways to sort the issue, so far without much significant success. I am still searching!
        • 18903
        I would seek out a professional supplier then Barry. You need to carry out what is called a “face fit” test. That will tell you exactly what size mask you need. Just buying off the shelf, if you don’t know what size you need, is a bit of a guessing game otherwise.
          • 18903
          Originally posted by Murfie
          Barry, for what it's worth, I wear specs myself and use a 3M 6051 respirator which is inexpensive as are the filters. No fogging and very comfortable with the specs.
          That’s my weapon of choice as well. Excellent bit of kit.
          • BarryW
            • Jul 2011
            • 6010
            #110
            There is a thought. I had no idea that there are such specialists around! A good tip, thank you. I will make enquiries.
              • 18903
              Sometimes called a fit test, or a face fit test…google it and see what comes up….
              The other thing is that you need to be clean shaven, but your avatar suggests you are already :thumb2:
              • Airborne01
                • Mar 2021
                • 3968
                • Steve
                • Essex
                #112
                Blimey Steve.......
                Just join the queue mate!
                  Part of the editorial comment in the September 21 edition of Scale Aircraft Modelling magazine has some relevance to this thread ...
                  "There is no 'right' way to build a model, and our content is edited to reflect this, and to offer options and alternatives rather than presenting the work of a master builder and saying 'this what you should do ...'
                  I have no affiliation to this magazine and the intention is not to promote it, however, I thought the sentiments expressed were worthy of a highlight.
                  • rtfoe
                    • 9084
                    #114
                    I have no issues with any medium of application as long as it serves the specific kind of finish I want. It can even be from a cutip or sponge. Nobody's done a mini sized roller...that would be something to try.
                      • 18903
                      Cutips (cotton buds to the anglos) are hollow, you could easily make your own Richard…. :tongue-out3:
                      • dalej2014
                        • Aug 2021
                        • 507
                        #116
                        So. 16 months later I've finally bought a cheap airbrush! Not one to rush, obviously.
                        Going well so far. That is paint is spraying, and cleaning is ok. I've got a respirator, and am just doing short "bursts" (pardon the pun!).
                        Will post results once I have some; so far just touched up the Toon Tiger.
                        • adt70hk
                          • Sep 2019
                          • 10409
                          #117
                          Dale
                          Welcome to the club.
                          I got my first airbrush probably about 4 1/2 years ago. I had two come with the compressor I got, cheap Chinese ones. One was a bottom feed and no good, the other was a side feed and worked ok once I got to grips with it. Whilst I probably could have saved myself a bit of pain in terms of the quality, what it did do was to give me a plenty of practice in how to use an airbrush and especially strip one down in the event of problems..... without running the risk of wrecking a decent one.
                          That said my most expensive one only cost me £100, which has a 0.2mm needle and I use for when I want a decent finish my other one was only about £60 and has a large cup with a 0.4 mm needle and so is perfect for things like priming and varnishing.
                          Looking forward to seeing it in use.
                          ATB.
                          • dalej2014
                            • Aug 2021
                            • 507
                            #118
                            Thanks Andrew. I'm already looking at H&S and Iwata models, the former my preferred route for intechangability and ease of cleaning. Some of the prices are eye-watering, but I expect it to be an investment to last a lifetime. I've been quite pleased with my cheap airbrush so far.
                            • adt70hk
                              • Sep 2019
                              • 10409
                              #119
                              Some of the prices are eye-watering.....
                              Aren't they just!!
                              My 'expensive' one was a personal recommendation from someone I used to know on another forum. He had tried about 30!!! Everything from super cheap to ridiculously expensive.....and this was the best he'd ever used. Mine is officially a Tamiya Superfine but the key components i.e. nozzle and needle are Iwata.
                                • Jan 2019
                                • 6248
                                #120
                                I'm in your camp here Richard
                                In fact I don't actually enjoy usually an airbrush and only do so if totally necessary,(all the faffing about with the thing does my head in!!).
                                I prefer to use rattle cans on most areas,and hand painting where I can get away with it.... there, I've said it..
                                ....... Let the abuse commence!
