Help, new to airbrush.
  • Roadie
    • Mar 2022
    • 63
    Hi, as some of you know I’ve just returned to modelling.
    I’ve also just obtained my first airbrush, never used one before, so loads of questions.
    Acrylic or Enamel?
    Mixture ratios, with what?
    Paint manufacturers?
    Airbrush setup, air flow for paint?
    Cleaning?
    Additives to help your pair work?
    Sorry to be a pain
    Thanks Steve.
  • AlanG
    • 6296
    Acrylic for me personally. Still wear a mask when spraying though!
    Vallejo Model Air is already pre-thinned ready for spraying straight from the bottle (after a good shake/mix)
    Spray pressure for normal spraying is about 14-17psi
    Cleaning. IPA (not the beer) or a suitable acrylic airbrush cleaning fluid
    • slupanter
      • Jun 2010
      • 554
      Hey Steve,
      So I can only talk about my journey; I started with Tamiya acrylic and then later Mr Hobby, MRP and other lacquerish paint. I do spray Vallejo/AK/Ammo acrylic if I really have too.
      I spary Lacquers at 10-15psi mixed with Mr Leveller or IPA (not the beer) try 15
      Or Vall/AM/Ammo with Vallejo thinner at about 15/18-24psi, try 24
      Pressure is about how thin, controllable and nice the paint sprays.
      I would say buy some Tamiya 10ml and x20a thinner from John and have a play on a cheap kit.
      For Vallejo etc
      • langy71
        • 1950
        • Chris
        • Nottingham
        Welcome to the wonderful world of firing paint at stuff whilst trying to look all professional.....lol
        Acrylic or Enamel... well that's down to a personal choice, you'll end up using the type that suits you best... personally I never got on with enamels, and prefer to use acrylics... however some guys on here can get fantastic results with enamels ..
        There's a million and one different ideas for what to thin paints for airbrushing with, personally I tend to use the propriety thinner from the paint you are using ..etc Tamiya thinners for Tamiya paint.. and so on...(although Tamiya do produce a lacquer thinner for their paint and it's brilliant.. really works well with their Acrylics..) also be wary that one company's thinner may not work with another company's paint,
        for cleaning the airbrush afterwards I use 99 % Isopropanol Alcohol ... (it's cheaper than using a propriety thinner to clean with)..
        As for thinning paint, I use the rule of thinning it to the consistency of milk. sometimes I'll add a drop or two of 'flow improver' just keep the flow consistent, and cut down on 'tip dry'..(where the paint starts to dry on the tip of the needle, and then causes inconsistent airflow)
        As for set up, my advice would be to purchase a compressor with a tank fitted to it, the tank will store a constant and stable supply of air whilst you are working with it, and stop any 'pulsing' from the compressor..
        have a look around Youtube, there are loads and loads of video's that introduce you to using and airbrush, these are quite informative and easy to understand..
        for example...
        hope this helps
        • slupanter
          • Jun 2010
          • 554
          • Roadie
            • Mar 2022
            • 63
            Thanks so far guys, very informative.
            One additional question, when mixing your paint/thinners how do you transfer your paint to your mixing pot, pipettes or syringes.
            Cheers Steve.
              • 18930
              Look for disposable pipettes Steve, they are very cheap and are literally made for that type of job. Here are some….
              They can also be used for transferring paint from the mixing pot to the airbrush. Don’t mix paint in the airbrush, by the way, It can cause blockages if the paint isn’t properly mixed.
                • 15735
                Hi Steve
                Lots of very sound advice already given which can act as a perfect starting point.
                However, whilst it would be great to have hard and fast rules there are just too many variables. For example, you open a new pot of paint, thin it 50/50 with the appropriate thinner and use it to spray your model. It sprays beautifully. A year later you take the same pot of paint, now half empty and thickened with time. On this occasion you want to spray small patches in a camo scheme. You use the same 50/50 mix and the same air pressure but this time the results are poor.
                You would need to thin the thickened paint more and reduce the air pressure and work closer to the model to get a good result.
                My advice is take onboard all the advice from the experienced guys but be prepared to adjust the variables to suit what you want to achieve.
                Practice makes perfect is very true when airbrushing.
                  • 18930
                  Don’t know about practice making perfect, but practice is essential….
                  • stillp
                    • 8097
                    • Pete
                    • Rugby
                    Even worse is when you use a pot of suitably thinned paint and it sprays beautifully, then you open another pot of the same paint, from the same manufacturer, thinned the same, and it's awful.
                      I don't think I can add anything - I think it's all been said....................
                      but - never mix paints in the airbrush cup! I use cheapo plastic shot glasses to mix the paint - if anything goes wrong ( like paint coagulating ), then you can throw the mess away - without having to clean it out of your airbrush!
                      Enamel/Acrylic? Smell! If you're in a garage, or hut, then that isn't a problem - inside your dwelling, solvent based enamels leave a lingering penetrating odour! ( I live in a mid-floor flat, so non-stink acrylic is ideal for me! )
                      As has been suggested, get a guinea pig kit to practice on - I've a harlequin coloured He 111 at the moment!
                      • adt70hk
                        • Sep 2019
                        • 10422
                        Steve,
                        Nothing to add. I still feel like I'm learning to use one sometimes she I've had one for a few years now...
                        If you don't have a 'spare' kit as a test piece, have a rummage in your plastic recycling......I have a couple of yoghurt pots for the purpose.
                        ATB.
                        • AlanG
                          • 6296
                          Plastic milk bottles are a good test bed too
                            • 18930
                            As are plastic cutlery….
                              • 18271
                              My take on the subject.
                              It depends:
                              On what type of paint. Nozzle size, air pressure. Are you fine detailing or block painting.
                              The only way to figure it out is grab the bull by the horns and enjoy the ride.
                              Thin paint, fine detail, low pressure and anlk that but watch you distance to target as well.
