I've been brush painting with enamels for years and I hardly ever use a primer. The exceptions are where there are -
different colours of plastic, such as the original Matchbox kits or when you've done a conversion using parts from different kits
contrasts between the plastic and the final colour, such as dark green over white plastic or pale blue over black plastic
large areas of patching & filling
In those cases I use a primer, but I don't use a proper primer, just whatever kind of pale- to - medium matt grey is convenient
This evens out colours and textures, and shows any uneven-ness, scratches, and so on
I often give the primer coat a very light sanding
If I don't use a primer the first colour usually needs two coats to cover properly, so you could say that it acts as its own primer .... or is that an undercoat?
Red, yellow, and pale blue paints are translucent, so you should paint those over a base coat of white anyway
I've found out all this from my existing enamel paints; various makes, but all quite old, and quite dense and cover well
But I've heard that modern enamels have been reformulated and are not as good, so perhaps you should use a primer more often - can anyone else comment?
