Layers of enamels required?
  • BattleshipBob
    • 6792
    • Bob
    • Cardiff
    Evening all
    Been using Colourcoats enamels for the first time to paint the hull of KGV, it's had 3 dust coats but it's still patchy, how many layers are normally needed?
    Thinning at 50/50 and 20psi??
    • 18266
    I normally give a dust coat then a wet coat. Job done.
    I find thinning a bit pot luck as some need more thinning than others. I go for 'thin until like milk'.
    • BattleshipBob
      • 6792
      • Bob
      • Cardiff
      What psi do you use Ian and about the usual distance, 6 inches or so??
        • 18266
        Good morning Bob.
        Just had a look. compressor is at 20psi on the dial, I am normally at about 2" for the smaller parts, 4 for the rest sounds about right. But I seldom spray with the air 'full on', I tend to hold back quite a bit.
        20psi might sound a bit high but works for me. Airbrushes are both bottom fed Badgers, so they need a bit more oomph than a gravity fed one. One is an Anthem 155 the other, my work horse, a Cresendo 175 the saving grace is that I can put a "glass" of paint on the bottom and spray a whole 1square metre in one go! lol
        • BattleshipBob
          • 6792
          • Bob
          • Cardiff
          Good morning Bob.
          Thank you Ian
          Just had another go and it's gone pear-shaped. Most of the hull is ok
          But the Paint has a gritty feel at the bow which means I am spraying too far away, nuts. Will have to let it dry and lightly sand the areas and go again, not happy, stupid mistake. I tend to stand while spraying but when my room is ready I can sit properly
          • Andy the Sheep
            • Apr 2019
            • 1864
            • Andrea
            • North Eastern Italy
            Thank you Ian
            Bob, I had the same problem with the clear gloss coat on my P70 and I found very useful to use steel wool # 0000 to smooth down the surface; it's only drawback is the large quantity of steel powder you will find on your bench at the end. Don't forget to wear latex/nitrile gloves to protect your hands: the steel wool as a whole ( :rolling: )is soft but its fibers can irritate your skin.
            Andrea
            • BattleshipBob
              • 6792
              • Bob
              • Cardiff
              Thanks Andy, I know its my fault and I need to get it sorted ASAP as I need to take all the equipment out and empty the garage, ready for a skip then the builders
              • BattleshipBob
                • 6792
                • Bob
                • Cardiff
                Just lightly rubbed all the hull down then run over it with a tac cloth, will repeat in the morning. Then another go!
                  • 18266
                  Maybe worth approaching like it's a tank. Instead of painting the hull as one big section, break it into sections, even hull plates if they're there. It could give a good effect as well.
                  • JR
                    • May 2015
                    • 18273
                    Ah the mention of a tac rag/cloth .Don't see it mentioned much Bob.
                    Can't help with the enamels sorry.
                    • BattleshipBob
                      • 6792
                      • Bob
                      • Cardiff
                      Good point Ian!
                      Hi John
                      Always used them, does pull a lot of dust to be fair and not expensive.
                      • BattleshipBob
                        • 6792
                        • Bob
                        • Cardiff
                        Well, another go. Looked poor with a nasty run. It looks better now its drying but still need to sand down the run. Started using the needle restricter which helped
                        Although it's my fault, think I will stuck to Mr Color lacquers and may stick with enamels for brushing, only issue the availability and postage?
                          • 18266
                          One last, silly but important question. You did remember to stir the shi snot out of the paint in the tin befor mixing the paint with thinner for spraying.
                          • BattleshipBob
                            • 6792
                            • Bob
                            • Cardiff
                            Hi Ian, stired it until I had a dizzy spell,but maybe even more required?
                            About to post pictures now the masking is off, be scared, very scared lol
