Letting a part dry after spraying
Arnold Judas Rimmer BSc SSc
''Happiness is a Triple Fried Egg Sandwich with Chilli Sauce and Chutney''Comment
You know it makes sense! I'm considering installing a small vacuum device to mine to remove those last dust motes that always seem to settle where they are least welcome!
Miko (taking proverbial a sledgehammer to solve peanut valued problem! Ha!)Comment
You wouldn’t solve it, you’d just make it worse. You’d be better off putting a filtered pressure feed on it. Any leaks in the arrangement would then blow outwards and not let dust in. All a vacuum device will do is pull in dust from the surrounding area. Clean room design 101…..work in a filtered air positive pressure environment to keep out contaminants.Comment
As a rule they ran their spray booths under positive pressure, to keep the dust out as you say. In the UK we run negative pressure. Not great as dust always tracks in from somewhere, but it stops the harmful fumes being blown out and reaching the unprotected souls outside!Comment
Miko (learning stuff today)Comment
Trivia but that reminds me of the debate we always had between US & UK vehicle painters.
I think I'll just paint myself pink with yellow spots and run around going slobby slobby slobby........oh wrong one ok I'll put some weight on and run around going slobby blobbyComment
