Painting small parts off sprue
  • barney178
    • Sep 2019
    • 12
    Just wondering what people use to hold small parts when painting off the sprue? Happy for homemade ideas or a ready to go solution.
    Many thanks in advance.
    David
  • Steven000
    • Aug 2018
    • 2826
    • Steven
    • Belgium
    I glue small parts onto cocktail sticks, with hotglue (bit of hotglue onto stick, then put part into glue) or super-glue
    • Mark1
      • Apr 2021
      • 4156
      Stick to masking tape or blue tack, drill a small hole somewhere that can't be seen and use a cocktail stick or glue a piece of sprue and snip off after painting.
        • 15668
        I tend to favour Mark's idea. Drill a tiny hole somewhere on the part where it won't be seen. Use CA glue to fasten the point of a cocktail stick into the hole. Paint the part. The cocktail stick will snap off when done.
          Usually my fingers But occasionally I use locking tweezers.
          • Gern
            • 9212
            If it's got a small pin to attach it to a bigger piece, try one of those tiny electrical crocodile clips. I've got about a dozen and I use them all the time.
            • Andy T
              • Apr 2021
              • 3239
              I mostly use small crocodile clips mounted on skewers, but use everything from blutack, double sided tape, ca or hot glue to stick small parts to something I can hold.
              Often I'll remove a part from the sprue but leave one of the gates and a bit of sprue attached, so I can hold it with that.
              Occasionally I'll use a push pin as pictured below. Heat the end with a lighter and it'll melt its way into the plastic part.
