Using masking fluid
  • BattleshipBob
    • 6792
    • Bob
    • Cardiff
    Using masking fluid
    Good morning from a sunny Cardiff ( for once )
    Just started using masking fluid for the first time. What do you clean the brush in????
    The Mr Hobby bottle is of course in Japanese, of which I know bugger all lol
  • Scratchbuilder
    • Jul 2022
    • 2689
    I usually use white spirit or IPA and then rinse the brush in soapy water to get rid of the chemicals.
    • flyjoe180
      • Jan 2012
      • 12381
      • Joe
      • Earth
      Here's the website Bob, pick your masking fluid for details. If it's Mr Masking Sol R then it's water soluble, you can clean your brush accordingly.
      株式会社GSIクレオス ホビー部が展開する模型商材ブランド、Mr.HOBBYの公式サイトです。製品情報、お問い合わせ受付、How To を掲載しています。
      • Scratchbuilder
        • Jul 2022
        • 2689
        Damn, I forgot about this, and its in my files as well.
        • boatman
          • Nov 2018
          • 14451
          • christopher
          • NORFOLK UK
          WELL Bob matey i use humbroll maskin as that is very good an its a pink colour so you can see if you have missed a bit a i used this on all them bridge windows on my tiger an they came up good an to remove it just use a needle an it will stertch off like very thin rubber
          chrisb
          • Waspie
            • Mar 2023
            • 3488
            • Doug
            • Fraggle Rock
            I use Humbrol liquid mask. Only used a brush once, too much faff cleaning brush, (IPA followed by washing up liquid the rinse).
            Now I simply use a cocktail stick and stuff the cleaning!!!!
            • BattleshipBob
              • 6792
              • Bob
              • Cardiff
              Many thanks Joe, have bookmarked it!!
              Great, appreciated
                • 18266
                I use the one from Vallejo and 'IF' you can get it before it dries washes out with water. Otherwise my cureall go to: Xylene, it'll get the stripes of a Zebra! Not yet found a paintbrush it cant clean!
                  • 15668
                  Like Doug, I find a cocktail stick far better to apply mask with. You can put on a small blob and push it where you want. Great for along edges and into corners.
                  • JR
                    • May 2015
                    • 18273
                    Small brush and a cocktail stick as Jim says Bob.
                    Sunny , stand by for rain then :nerd:
                    • Waspie
                      • Mar 2023
                      • 3488
                      • Doug
                      • Fraggle Rock
                      Nice to know - I have 5lts sat in the garage!!!
                      • Jostro65
                        • Mar 2021
                        • 57
                        Hiya, not sure of the Mr hobby stuff but I use Vallejo and applied with a brush first time used it. Messed up brush so now I apply with cocktail sticks as find can be more accurate and no worries about clean-up.
                        • BattleshipBob
                          • 6792
                          • Bob
                          • Cardiff
                          Used Mr color and very impressed, brush easy to clean with water and peeled off with pointy tweezers.
                          • davecov
                            • Jul 2014
                            • 830
                            • Dave
                            • Stow, Scottish Borders
                            My favourite is Microscale Micro Mask. Brushes clean with water.
                            DaveCov - Founder of The Airfix Tribute Forum 2006
                            • Watto
                              • May 2024
                              • 62
                              I agree with davecov, I've had some good results with Microscale masking.
                              A while ago, I brought a small sonic cleaner, the type of thing for cleaning jewellery.
                              I rinse the brush and dip it into the water in the cleaner and give it a few seconds, you can see the brush actually cleaning.
                              I look after all my brushes by cleaning them with brush restorer which is lower sodium soap.
                              Watto.
