Hi to All!
I want to do a block of solid "water" for my crashed SIG.
At first, my intenttion was to do with "still water" of Vallejo.
This product have several problems ... for a good transparent color it is necessary to go superimposing thin caps of product, if you do fast in one rapid time, the central part is never like dry and stays badly of visibility. The size of the block that I want to fill is big, to use this product supposes doing caps of 1 or 2mm every two days!!! In August I will be still to the half!! I have discovered that with the time it shrinks and deforms!!!(Shanina's dio, I will return after the battle)
Someone of you have worked with resin or similar?? They are the sufficient thing be transparent to create water?? Have you some advice please??
Best regards
Polux
Best regards
Polux
