Hi,
Had a bit of a problem tonight whilst using Maskol for the first time.
I used as directed on the bottle and masked a section of acrylic paint, then airbrushed what I need to do, waited 1 hour to dry and removed the Maskol. On removal it took some of the acrylic paint away from underneath the mask even though the paint it removed was absolutely dry as it was sprayed 3 days ago.
It actually looked like it had dissolved the acrylic slightly on removal.
Have any of you guys had this issue before, is it meant mainly to be used with enamels, and would I benefit from a coat of Klear on acrylic paint before using Maskol?
Atb, Colin.
Atb, Colin.
