Hairspray technique problems
    Hey guys. Can anyone let me know what i did wrong here? I had a solid clear base down on top of my base coat of grey. then i sprayed a layer of hair spray on top of that. Let it dry for 1.5 hours, then sprayed the white on top of that. And i got this cracking all over the model.
    Did i not let it dry long enough? Anyone who's done the hairspray technique before, how long did you let it dry before applying the top coat?
    Thanks.
    [ATTACH]49485.IPB[/ATTACH]
    are you using acryllic paints if so it sometimes reacts to the paint
    mobear
      yea. tamiya acrylics over the hairspray. i watched some youtube tutorials and they said it didn't matter what type of hair spray, and the process only works with acrylics.
        i did the same type of thing with my lancaster,i sprayed a little too much in one area,and it caused wrinkles,and some hairspray is worse than others,so i now use stuff that you hand pump
        mobear
          so you think the problem was too much hair spray? is it more of a misting or a "coat" of hairspray? i had tested it a while ago with a coat and it was fine. frustrating...
            more of a mist then you can add more if required,though i think some of the more experienced modellers could give you more idead of the problem,as i`m still quite new to this model build,i only started doing models just before xmas last year
            mobear
              • 18269
              Just to really get things up in the air, I have painted hairspray on with a flat brush over Humbrol then sprayed acrylics over the top with out any problems. Ypu can also use Humbrol Matt paints over the top, it's just harder to chip afterwards.
              I use Vallejo acrylics by the way.
              I know it's not the effect you are after but you have gotten a nice distressed paint effect.
                Why do you apply hairspray to models???
                Mike
                • Centurion3RTR
                  • Jan 2009
                  • 2093
                  Originally posted by \
                  Why do you apply hairspray to models??? Mike
                  Hairspray is water soluble Mike, so you have your first layer of paint then hairspray. Then you put a different colour on top of that, and when thats dry you chip away with a wet stiff brush so it looks like worn paint. You can get a good effect too, i've only tried once and this was the result.
                  [ATTACH]46527.vB[/ATTACH]
                  Have fun, John
                  [ATTACH]49529.IPB[/ATTACH]
                    That's totally amazing John!
                    • Centurion3RTR
                      • Jan 2009
                      • 2093
                      My wife would disagree, but the model is great lol
                        LOL I feel ya there good buddy...
                          Do you think a small toothbrush would work just as well? I mean on a larger scale basis?
                            Yes, toothbrush, toothpick, anything is worth a try
                              Andy, HOLY MOLY! WHAT A GREAT BUILD! Your a model master!
                              Mike
