Hi all!
In a very compelling oil wash demo, a Mig 502 Abteilung Oil is thinned with Humbrol Enamel Thinners with a 50/50 ratio, and is applied over a gloss coat (they don't say which product). Based on this I have also tried to make a wash with a Mig 502 Abteilung Oil (Engine Grease) but I haven't had much success :-(
I'm using Vallejo Model Air (Acrylic) as the base paint and have tried two combinations:
Attempt 1
- Vallejo Gloss Varnish, giving 48 hours to dry and cure
- Mig Odourless Turpentine, but with a ratio of 10/90 oil to turpentine
Problems
Attempt 2
- Pledge Multi-surface wax (the new Klear formula). Again giving 48 hours to cure.
- Winsor and Newton Artists White Spirit (again with a ratio of 10/90)
Problems
I have yet to do a third attempt (Perhaps Vallejo Gloss Varnish and Zippo Lighter Fluid) but before doing so I wanted to see if anyone else has had success making a wash with these oils.
Also, what ratio should be used? In the demo it's 50/50 which seems really high compared to the various wash tutorials I've seen.
Thanks for your help!
Tony
Attempt 1
Problems
- The wash just will not dry, it's now been four weeks! I've read that as turpentine ages it yellows and takes longer to dry. Perhaps I bought a very old bottle? I even tried letting the oil sit on top of a sheet of cardboard to draw out the linseed oil but that didn't seem to make much difference.
- No capillary action... I literally had to push the oil down the groove
Attempt 2
Problems
- The wash traveled down the groove with some capillary action (still need a tiny bit of nudging), but when I looked again 10 minutes later, most of the wash had literally been repelled out of the groove!
- The mess dried fairly well within a couple of hours, but after cleaning, the surface was slightly stained.
Tony
