decals that decalsoft doesn't work on
  • mossiepilot
    • Jul 2011
    • 2272
    I've just started using Revells decal soft. I've used it on two different planes from two different companies. With the Academy decals it was a complete failure and with airfix decals it did just what it says on the tin, or bottle in this case.
    Question is, are the Academy decals a one off and just a poor batch or is this decal softener only good for certain makes of decals. I have kits from most of the major producers and just wondered if you guys have had similar experiences.
    Tony.
  • flyjoe180
    • Jan 2012
    • 12381
    • Joe
    • Earth
    I use Humbrol Decalfix. I have the same issues only with Academy decals. Even the ancient, slightly discoloured Airfix ones settle better than the Academy decals I have used. They just seem to either sit stubbornly on top of detail and not settle, or just disintegrate.
    • stona
      • Jul 2008
      • 9889
      Some decals just won't react to the decal softeners. Some may over react. I always try and test with an unwanted decal from any sheet.
      If your softener doesn't work you can try another brand,some are stronger than others. Alternatively you can apply home made remedies.
      I've tried two but both need considerable care.
      First try a good old hairdryer to soften the decal,be very careful not to soften the model!
      Second is even more radical and only for the brave or desperate
      Cellulose thinners.
      You must do an experiment on an unwanted decal. Cellulose thinners is a concoction of several different solvents and can differ considerably. I tried this with the bog standard stuff from Halfords.
      Don't flood the area with thinners,you will dissolve the decal and you will remove your paint. Dip a fine brush in thinners,wipe it virtually dry and carefully apply to the decal and decal film only. It's up to you to judge when this is working but start with very,very little and carefully add more.
      It's easy to destroy the decal,as I found out the hard way. I also found that some bubbling can be smoothed with a water wetted brush.
      Good luck.
        • 18266
        Mirco sol don't work that well on Academy decals either. It gets the job done to a point but takes a lot of applications. Well the ones I have had my hands on anyway.
        • Adrian "Marvel" Reynolds
          • Apr 2012
          • 3008
          I did read someplace that white vinegar is also a good liquid to help soften decals, if you smell Micro Set it smells the same
            the setting agent is basically water. acetic acid (vinegar) and detergent.
            its on the health and safety sheets for hospital ingestion protocols.
              • Apr 2012
              • 3008
              Originally posted by \
              the setting agent is basically water. acetic acid (vinegar) and detergent.its on the health and safety sheets for hospital ingestion protocols.
              So can I use it on my chips
                Mirco sol don't work that well on Academy decals either. It gets the job done to a point but takes a lot of applications. Well the ones I have had my hands on anyway. Ian M
                have you found anything that does work well with academy decals because i like their kits.
                • Gern
                  • 9212
                  More use there than on Academy decals! :lol
                  Gern
