Painting landing gear wheels
    we get a lot of foreign coins at the office so i find one the same size as the hub hold it in place the paint around the coin.
    Scott
      Originally posted by \
      a method i tried recently was to wedge a rod in the hole then stick said rod into my dremel with the idea that i would paint the black wheel slowly whilst rotating rather than moving the brush, if you know what i mean. problem was that i forgot to turn the speed of the dremel down first...............still havnt found the blasted thing.
      Sheesh, I just bought a Dremel yesterday. Will try not to get too ingenious ... had a gut hurting burst of laughter too. Thanks.
        So right Frikkie. I have now laughed at this so many times. My wife had a good chuckle.
        Have you recovered yet Andrew ?
        Thanks Scott. Did a similar thing some time ago with those coloured stickers. They come in a variety of diameters.
        • HAWKERHUNTER
          • Feb 2012
          • 1589
          • Steve
          • Halifax, West Yorks.
          #19
          Hi Laurie
          I paint the hub first and then use a black felt tip marker pen to run around the area where the tyre joins the hub. This black line creates a safe area where the tyre joins the hub. I then just paint the tyre up to the black line. Gets a perfect result each time and any colour variation between paint and felt tip is barely noticeable.
          steve
            Thanks for that Steve which is another great suggestion. Tried others on the main gear. Will try yours on the tail.
            • Dave W
              • Jan 2011
              • 4713
              #21
              I tried Tony Yak faces method last night and it works really well.Now Ive got 4 nicely painted Phantom wheels.
