I've been practicing airbrushing on several pieces of gash model parts, successfully using Vallejo "Acrylic Polyurethane Surface Primer 73.601", Xtracrylx paint thinned 2/1 paint/thinner with Xtracrylx "Thinners". OK. But I then used Vallejo "Model Color 70.953 Flat Yellow" thinned. The AB gummed up after about 20 secs. I noticed that the paint in the cup had coagulated and was difficult to remove so I did a full clean (needle out, the three nozzle bits out). When returning the needle to its full forward position I noticed a yellow worm coming out of the nozzle. So I cleaned again, this time using one of those long thin AB cleaners.
== So what caused the problem? (Could it be that Xtracrylx Thinners and Model Color paints are incompatible?)
== If not, what happened? If yes, is there a thinner usable with both Vallejo Model Air and Model Color paints?
== Should I use one of John's Vallejo thinners:
"30ml Thinners (New Formula) Vallejo Model AIR 71.061", (or is "Model Air" different from "Model Color", thinners-wise), at:
Acrylic Paint Thinners for Model Paints
or
"17 ml Thinner (200), Vallejo 70.524" (which does not mention "Model Color" or "Model Air", at:
ScaleModelShop
== Also, despite thorough searching, I cannot find a clear explanation anywhere for the difference, concerning model aviation airbrushing, between Vallejo Model Air and Vallejo Model Color? Which is best, what's the difference in use?
Can anyone help please?
Thanks.
or
ScaleModelShop
Thanks.
