T-cut on canopies
    T-cut on canopies
    I read somewhere (in connection with using Eduard canopy masks — it might have been the seller of Eduard masks) that it is a good idea to use T-cut on the masked surfaces to make sure that they are clean and so make it easy for the masks to stick (which is obviously necessary, especially around the edges).
    T-cut is a mild abrasive (although shines cars OK) and contains ">= 50 % Aliphatic hydrocarbons and up to 15% Anionic surfactants".
    I rang the manufacturer and they advised against (not surprisingly), saying that it might turn the polstyrene milky.
    I have just done a test and after polishing it off there no sign of milkyness yet
    Is T-cut necessary? Would soap and water be sufficient to get good adhesion?
    Thanks.
  • Adrian "Marvel" Reynolds
    • Apr 2012
    • 3008
    Steve, I've always used Bare Metal Foil for masking my canopies and apart from a quick wipe over I don't use anything, I'd really stay away from T-cut for the reasons you say.
    Adrian
    • yak face
      • Jun 2009
      • 13840
      • Tony
      I dont know about the new formula T-cut steve , but the old stuff with its petroleum distillates would definitely attack the plastic , I wouldnt like to risk it with the new either . If it was me , I would just give them a good wash with soapy water and rinse , the masks should stick fine , cheers tony
        • 18269
        Soapy water, a good rinse and if you are into it a dip in Johnssonses Klear. Its about the only thing I use it for. Why? It does give a nice shine to the clear plastic and makes them appear thinner (!?). Also, should you have a minor painting issue, the klear, makes removing the boo-boo's easier.
        • rickoshea52
          • Dec 2011
          • 4076
          • Rick
          Steve,I use T-cut to remove the factory tampo printed numbers and nameplates from ready to run model trains when I want to re-number them. You get a nice glossy finish ideal for applying decals but I wouldn't use it on clear plastic.
            OK. I won't use it. At the recent Cosford model show I was given two identical pieces of advice on how to get a mirror finish on cars: after using Halford's car paint (spray can) use T-cut to buff it up, and again after applying a clear varnish (if varnish is necessary).
              didn't realise you were at cosford mate, you should of come for a coffee with us all.
              • stona
                • Jul 2008
                • 9889
                Can you still get that smoker's toothpaste? It was a powder and I used to use it to polish minor flaws out of clear parts.
                Generally I just give clear parts a quick soapy wash and then a wipe with alcohol before a dip in Klear.
                  I didn't check the forum during the weekend and missed the appointment at 12 noon (under the vulcan wing as I remember). Pity.
                    The powder was called Eucryl, and there was a liquid sort called Pearl-drops ... used both of these to buff out/tone down/thin and fade paintwork when i used to spray artwork on cars.
                    • Andy2035
                      • Aug 2011
                      • 730
                      I use one of these to polish up my clear screens, it takes out all the scratches etc...: - Albion Alloys Abrasives Triple Grit Polisher/Finisher 3210
                      I start off with the course and finish with the super fine...: -
                      Before...
                      After...
                      http://www.scalemodelshop.co.uk/triple-grit-polisher-finisher-albion-alloys-3210.html' rel="external nofollow">
                      • stona
                        • Jul 2008
                        • 9889
                        Eucryl,that's the stuff. Thanks for that. It worked really well,but I never brushed my teeth with it!
                        It still exists.
                        http://www.eucryl.co.uk/
