Hi - first post!
So a month or so back I got bored of waiting for my son to be old enough to properly appreciate my Airfix nostalgia... he's only 6 but seemed to love sitting with me and 'helping' build an Airfix 1:72 Spitfire. Happy to admit here (but not elsewhere!) how much more I got out of it than he did! We went and got a second... Messerschmitt 109E, so that the Spitfire had someone to shoot. At the same time, I started googling for tips on how to improve, especially painting, decalling & weathering, as the Spitfire was a bit slap-dash, and frankly it seemed interesting and I found the process really relaxing!
So have been more ambitious painting the Messerschmitt. Used a can of spray primer to start, thinned down my acrylics (Humbrol, came with the 'starter' kit) a bit (perhaps too much?) to do multiple thin coats to avoid brush marks, and got hold of some Tamiya masking tape to try for some nice crisp lines on the 109's camo.
And it so nearly worked!
Photos below, assuming they come out properly. You can see where the paint has bled through under the masking tape - sometimes just in fiddly places where the masking tape was difficult to apply (e.g. between the nose-mounted MGs/cannon [?] and the sticky-outy-engine-thingy on the port side forward of the cockpit), and sometimes running under the tape along panel lines.
So:
Any advice gratefully received.
It's not the end of the world if these don't come out perfectly - once they're varnished, decalled, weathered and sealed (satin cote a good choice?) then they're being handed over to The Boy as toys and will soon be beaten-up bits of plastic lost at the bottom of the garden! I don't mind, though, as I'm treating these as practice for when I do a plane "just for Daddy".
[ATTACH]63985.vB[/ATTACH][ATTACH]63986.vB[/ATTACH][ATTACH]63987.vB[/ATTACH]
[ATTACH]65226.IPB[/ATTACH]
[ATTACH]65227.IPB[/ATTACH]
[ATTACH]65228.IPB[/ATTACH]
So:
- What am I doing wrong? Perhaps I was a bit ginger applying some of the tape, worried that the lower coat would come away when I took it off, but was a bit more brutal with later taping. (No sign of any paint coming off anywhere - is this because of the priming? Do I get a Brownie Point?)
- How do I fix it? Following advice I've been painting in progressively darker layers, so the runs are all dark on lighter colour. I really don't want to leave any brush marks and think I will if I just paint over with unthinned paint, but guessing that thinned paint won't cover? Do I have to remove the paint? If so, how?
