OK - think I'm getting there as far as confidence (ie. "giving it a go") with the airbrush goes and using it to do basic coverage however I'm still concerned that when applying the paint (usually matt Tamiya acrylic over Halfrauds grey primer) the finish is very "rough", both to the touch and in appearance, in the right light. I am thinning the paint approx 1:1 and when I tried to thin more as a test it just came out like water. Any suggestions there?
Is it the primer that's causing this rough finish perhaps? Will the finish soften up with an application of a varnish maybe? Am I not thinning enough?
Any help greatly appreciated - I posted up my attempt at pre-shading recently which looked ok but that too felt very rough indeed - and yes, now I've sprayed over with a darker colour in the camo the pre-shading in those areas is obliterated!! All a learning curve I guess...
