Originally posted by \
Red Arrows: Which Red?
Originally posted by \AS far as primer goes if you want one for the airbrush I can recommend the Vallejo range. Dry flat and smooth and if left to cure fully is as hard as nails.I'll just add that for a good red finish that pops, try a yellow undercoat.
The German Dark Yellow looks a bit dark and murky so I assume that after the White primer I would be able to undercoat with something like 71.002 Medium Yellow, would that be best?Comment
One rule us Gw guys stick to is this, Black primer if you want the models to look dirty and grubby, Grey primer for nuetral and white primer if you want pop and vivid colours. there are exeptions to this rule like pink under red will make a red pop, yellow under red is the same, Your playing with the transparancy of the final top coat. you can get some plastic picnic spoons normally dozen for a £1 or £2, try on these all the diffrent combinations you can think off and make a note as to what you like. once you have figured it out then go to the model.Comment
Thanks Matt, I haven't even had a first try at airbrushing yet, lol.
I've got some old 4 pint plastic milk bottles to practice on as well as some inkjet paper. I'm just making sure I'll have everything I need before I start.
I'm also trying to eliminate as many variables as possible so I'll have a rough idea of what to expect, and can hopefully gain some skills as I progress.Comment
Originally posted by \Thanks Matt, I haven't even had a first try at airbrushing yet, lol.I've got some old 4 pint plastic milk bottles to practice on as well as some inkjet paper. I'm just making sure I'll have everything I need before I start.
will see if i can find my first attempts pic that i took
Matt
Hi Andy, from one noobie air brusher to another, the best advice I ever got was, just do it. Once I got over my nerves about using the air brush on a carefully built model,I was able to move on. I still make lots of mistakes, but I try to learn from them, sometimes I don't and make the same mistake again, just done it today trying to air brush varnish onto NMF F-86 and buggering it up, again, but I'll get there. Go on mate, have a go.
BTW I saw at the top of your thread you were looking for paint conversions, have you seen this -
http://www.paint4models.com/
I use it quite regularly as I only use vallejo paints and need to convert kit paint suggestions to vallejo colours.
Have fun.
Tony.Comment
Originally posted by \what have you got airbrush and compressor wise.
I done lots of scouring the 'net for reviews and advice before I made my purchase, and hopefully it'll serve me well.Comment
Originally posted by \I've got an Iwata Revolution CR that I got from John's SMS Ebay shop. with an Airbrush Compressor AS186 with a 3L tank.I done lots of scouring the 'net for reviews and advice before I made my purchase, and hopefully it'll serve me well.
matt
Originally posted by \Oh Andy, before I forget, remember you'll need some solvent for the xtracrylix - Vallejo airbrush cleaner has been suggested elsewhere. Having used airbrush cleaner with other paints I'm trusting in this advise.Cheers, P
I'm no chemist, but I do know that the thinners contain the same acrylic polymers as the paint but are just in a thinner medium. So although you are diluting the paint to make it thinner, you are adding more of the same binders.
You can use distilled water, but that also makes the weaker and if over thinned you can actually rub it off when you handle the model.
Airbrush cleaner is designed to break down the paint. Destroying the paints ability to bind.....
I'll pull up a chair now and sit back and await the rebuttals
Ian MComment
Originally posted by \Buy some Vallejo thinners for airbrush. Thinners are thinners and dilute the paint. Airbrush cleaners, break the paint down. I have read that people have used cleaner as a thinner but I would advise against it.I'm no chemist, but I do know that the thinners contain the same acrylic polymers as the paint but are just in a thinner medium. So although you are diluting the paint to make it thinner, you are adding more of the same binders.
Ian MComment
As a foot note: If you use the airbrush thinner to thin paint for brush painting it will 90% of the time make the paint drag. The 'Ordinary' thinner can be used in an airbrush, just add a drop or two of distilled water.
If you are an airbrush user, I can recommend that you buy a big bottle of airbrush thinner and a little one of the other thinner. I have sent a pretty good spay job tits upwards using airbrush thinners to thin with a brush for spotting and touch up. It just dragged up the sprayed paint even though it was three days dry.
Ian MComment
I would keep with the thinner for thinning and the cleaner for cleaning
Sent from my HTC One using TapatalkComment
