DISASTER HELP!
  • peterairfix
    • Jul 2012
    • 11075
    DISASTER HELP!
    I had just finished my dalpol evening star tender and i had put a top coat of gloss varnish on and left i overnight and my horror i found this (see pic) can this be cured or will i have to get a new set of decels,all paint i am using is humbrol acrylic.
    [ATTACH]78698.IPB[/ATTACH]
    • 18269
    Ouch!
    I believe the technical term for this is "Naff".
    In all honesty, I would take them off and get some new ones.
    If the emblem in the centre can be saved, maybe paint the coach stripes.
    • peterairfix
      • Jul 2012
      • 11075
      Thanks i think new decels will be the way to go but i will try somthing else and see what happens.
      Peter t
        oooh!! it would be interesting to see if any kind of recovery could be made with Micro sol and micro set,
          • 18269
          Its already been varnished. That would just be a waste of time and Micro sol/set.
          • peterairfix
            • Jul 2012
            • 11075
            I seem to have sorted it sort of by carfully peeling away the damaged bits heres the result.
            Peter t
            [ATTACH]78732.IPB[/ATTACH]
            • spanner570
              • 15402
              Peter, as you've been able to peel off some of the dross, it could still be worth having a go with micro sol.
              When I do my decals, I cut as close as I can to the actual colours, thus removing any excess film before dipping in water. No help now I realise, but worth trying in the future.
              • eddiesolo
                • Jul 2013
                • 11193
                Looks like you have managed to salvage it Peter.
                Si
                • peterairfix
                  • Jul 2012
                  • 11075
                  Looks like you have managed to salvage it Peter.Si
                  Thats the best side the others much worse if i can't get it any better i will get new decels.
                  Peter t
