iv been using the Vallejo matt varnish along with the satin and polyurethane for a number of years and have had no problems ,but I have heard that humbrol is good also .
Humbrol Clear...
Hmmm I might change to Humbrol clear as well. Does it need to be thinned for Airbrushing Barry?
JohnComment
Also add to this thread that to increase the glossiness apply additional coats until the effect required is a achieved.
LaurieComment
To add my tuppence worth.
What ever varnish or paint you use its the 24 hrs or more you leave it afterwards that gives you a good result.Comment
Agree with you Harry if you are going to work on the varnish surface ie decals weathering etc.
However with recoating then 30 mins for Humbrol Clear and 60 mins for Vallejo Acrylic and the surfaces are ready for a recoat. I do however take great care to ensure dust has not fallen on the pieces in that time as I would not want to wipe down with a cloth until your time Harry of 24 hours.
Vallejo Polyurethane recoat I would give much longer as it lingers.
LaurieComment
Folks, this has been a really useful thread - thanks very much. I've been struggling to get good results with the Vallejo varnishes, so it looks like I'll try Clear next.
Barry you don't work for Humbrol do you?Comment
I just picked up some Humbrol Clear to use in my airbrush and have a few questions.
Approximately how long should I wait between coats? 20 mins enough?
Has anyone tried it on top of Humbrol enamel? I am a bit unsure since it seems to be water based.Comment
Just found the answer Daniel plus a few more. Note this is direct from Humbrol.
In this video we show you the uses of the new Humbrol Clear Gloss Varnish.
Humbrol products used in this video:
- Humbrol Clear 125ml
- Humbrol Acrylic Spray Matt Varnish No.49 - AD6049
We strongly suggest you practice the techniques using a test piece first.
Please note that this item can only be delivered to UK addresses
A thin clear varnish that goes on clear and stays clear. Humbrol Clear drys to a low gloss finish, a higher gloss finish can be achieved by applying further thin coats.
Usage
A water-soluble, self leveling gloss medium that can be prepare painted surfaces for decals, as a gloss varnish and to improve the appearence of clear parts.
Substrate
Humbrol Enamel and Acrylic Paints.
Application
Apply thinly with a brush or airbrush. To achieve a high gloss finish, apply additional coats.
Drying Time
Surface dry in 30 minutes. Recoat once dry.
How to Clean
Water.Comment
Thanks a lot, seems it is fine to apply over enamel then. I will try on a test piece first and wait 30 mins between coats and see how it goes.Comment
I think , Daniel, that 30 mins is an approximation. I would make sure it is more than touch dry or you will get horrible puddles.
LaurieComment
