painting problem
  • Ash
    • Apr 2014
    • 5
    painting problem
    Hi, im painting my 1/48 model spitfire and im fairly happy with the camouflage part, im now painting underneath with a pale green colour paint. im using acrylic paint but im getting hard lumps appearing here and the on my model where ive painted. why is this please? do i need to stir the paint in the pot it comes in more or what i dont know. heres a picture of what ive done http://s895.photobucket.com/user/alecras234/media/WP_20140406_0011_zpsb95cb230.jpg.html
  • Alan 45
    • Nov 2012
    • 9833
    Hello Ash it looks like it needs stirring , the paint looks like it's separated from the pigment
    • Ash
      • Apr 2014
      • 5
      i use a cocktail stick to stir but i never know when to stop stirring. Also do i apply acrylic paint thinly, how many coats?
      • eddiesolo
        • Jul 2013
        • 11193
        It does look like it isn't mixed properly Ash. Are you using a paintbrush or airbrush to apply?
        Si
        • Alan 45
          • Nov 2012
          • 9833
          All you have to do is to stir until all the pigment and all the paint is smooth
          It's best to give two thin coats even a third if need be also only load your brush half way and wipe it once both sides of the brush
          I hope this helps you out
          • Ash
            • Apr 2014
            • 5
            im using the old hairy stick haha, a brush
            • Alan 45
              • Nov 2012
              • 9833
              I'm a hairy stick chap
              • eddiesolo
                • Jul 2013
                • 11193
                As suggested thin coats, dried between coats will give you the best results Ash.
                Si
                • eddiesolo
                  • Jul 2013
                  • 11193
                  No comment.
                  Si
                  • Ash
                    • Apr 2014
                    • 5
                    is using a cocktail stick to stir paint ok? do i pour the mixed paint into something?
                    • eddiesolo
                      • Jul 2013
                      • 11193
                      Some paints have a small ball bearing or plastic ball in the bottle to help in mixing, if you don't have one then you can help the initial mixing by shaking and then rolling the bottle across a work surface-this helps to agitate the pigment and binder, once done you can open the bottle and a cocktail stick or even the end of a thin paintbrush to mix again-pour a bit out onto a painting palette and see how it is mixed together then start to paint. Use a small bit at a time and once you have got what you need re-seal the bottle-acrylic paints will last 24hrs or so if covered but will dry out quickly if left in a warm environment-not much chance if using a bottle but it saves on spillages too. Once you have done some painting and the first coat is dry, remix the bottle to agitate the contents again before dipping in to do a second coat.
                      Si
                        Ash, I've always found the best paint stirring rule is stir, stir & stir again ...once you think it's mixed ok ... stir some more to be sure!
                        http://www.scale-models.co.uk/threads/%C2%A31-battery-powered-paint-stirrer.15909/
                        There's a link to a stirrer I made for £1 - it might help.
                        Patrick
                          Ash a bit of information. Are you airbrushing and it looks like it.
                          What paint are you using and are you thinning and if so with what ?
                          Airbrushing is the brush clean. Assuming an airbrush can you see the darker green streaks in the paint cup when you put it in.
                          To give some idea slodge a bit out on paper and see if you get the same result.
                          Always think it is good practice to try a 5 sec or so practice burst on a plastic bottle. This normally or at least on average shows up if the paint is weird or the airbrush is not doing its thing.
                            Ash, I've always found the best paint stirring rule is stir, stir & stir again ...once you think it's mixed ok ... stir some more to be sure!http://www.scale-models.co.uk/threads/£1-battery-powered-paint-stirrer.15909/
                            Patrick
                            Pound land do a milk frother, straighten out the whisk and this works as well.
                              Laurie,
                              Ash said that he's brush painting! Scroll up old chap
