Tips on silver/metal finish using a brush?
    Cheers Laurie he is staring to love it but think there will be a lot of dad intervention for a while lol
    Cheers Paul
      Maybe aluminum foil is another option.
      there are different brands of foil with different colors.
      Here are three examples.
      http://forum.largescaleplanes.com/index.php?showtopic=46336#entry492130
      http://forum.largescaleplanes.com/index.php?showtopic=31521#entry284127
      http://forum.largescaleplanes.com/index.php?showtopic=46079#entry487451
      get a bottle of microscale metal foil adhesive and try it out..
        I agree with Ian M.
        I did that with my first model returning to the hobby since being a kid, and it turned out very well, so would be even better done by someone knowing what he's doing
        • tanktrack
          • Jun 2012
          • 1429
          #19
          this post has given me an idea for my sc1
            I normally use Revell's enamels for metallic brushed on finishes...
              morning all
              right i have come to the conclusion that i will have a go at my Sabre will a rattle can primer and a metal finish silver also from a rattle can.
              mainly because I found a unopened can of both in a house move so will test them and see if they haven't gone off.
              anyone got any useful and easy to follow tips for an absolute novice and his 7 year old apprentice on how best to go at this.
              cheers Paul
              • yak face
                • Jun 2009
                • 13841
                • Tony
                #22
                Sounds the easiest to me Paul . Ive done a lot of silver finishes using just this method. the best advice I can give is use short bursts of the aerosol , make sure youve got plenty of ventilation and a couple of masks ,and have a practice first. If youre too close it will be too thick and wet and will run , too far away and it will dry before it hits the model and result in a grainy finish, just have a bit of a play first, I'm sure youll quickly get the hang of it. cheers tony
                  Tony's spot on, nice short bursts, start spraying to one side of the model and sweep the spray across it, don't stop spraying until you are past it. Have a practice on a plastic bottle. A few thin coats are better than one drippy thick one. If you have problems you can get a reasonable finish with a brush. Here's one I am in the process of doing. I used a one centimetre flat brush and thinned the paint until it was like milk. The front panels are silver with a little drop of black in the mix and the fabric on the wings and fuselage are aluminum with a drop of white added. I did about 4 coats of each. Don't go back over what you've done and its fine, it will look blotchy at first bu t comes up ok.
                  [ATTACH]81408.IPB[/ATTACH]
                  [ATTACH]81409.IPB[/ATTACH]
