On the Easy Eight project the time has come to start weathering. I am at a loss for the wash I want to use.
I got the Vallejo weathering set for green vehicles and it comes with a couple of washes. I had intended on using this set according to their recommendations, but have started second guessing myself. I tested the green wash on an inside wheel to see what it would look like and decided to try out all of the wash options I have.
First, I sprayed Vallejo Olive Drab primer as my base coat. Then, I went to work. Here is a list of the washes I used:
Vallejo dark green wash (out of the bottle)
Testors CreateFX acrylic black wash (out of the bottle)
Windsor-Newton Oil Burnt Sienna thinned with mineral spirits
Windsor-Newton oil Black thinned with mineral spirits
Here is how they worked for me:
Vallejo has a really nice, thin consistency, and flows nicely. But, it goes on more like a very thin coat of paint instead of what I would call a traditional wash. It doesn't seem to accent the nooks and crannies. The color seems a bit green, but apparently that is the way it is supposed to look as it will be toned down a bit with the rest of their recommended steps.
CreateFX is a little thicker, but flowed nicely as well. It is a blackish-gey color and also seems more like a really thin paint. It doesn't seem to collect in corners and such either.
Both W-N oils flowed nicely and collected in the corners and around detail. The burnt sienna seems a little red to me.
Here is a photo that might give you a better idea. The last wheel is bare OD primer (the base coat).
Hopefully the photo shows up better to you all than it does for me. I have a lot of glare on my screen right now.
After typing all of this, I am leaning towards my original plan and using the weathering set just to see what the final result will look like, however I would like some of your feedback.
