Washes?
    Washes?
    Right I'm halfway through painting some figures and I'm totally confused when it comes to washes, highlighting and weathering etc. Where do I apply it? What wash should I use? Do you use it when the figure is finished? Here is the figure in question [ATTACH]285645[/ATTACH]
  • col68
    • 1505
    Hi jack nice work on the camo .
    Normally I would apply my washes after the figure is assembled and the paint work has been sealed with a couple of coats of gloss varnish.as for washes I normally paint my figures with acrylics so I use citadel's agrex earth shades for shadows and creases then I highlight with the original base colours lightened with a drop of white paint.
    HTH
      HTH
      Thanks for the help col. didn't realise I should gloss them, will this not make them really shiny? Do you buy ready made washes or is it better to make your own? Been watching some YouTube vids going to practice on some old figures first don't want to ruin these ones. Thanks again
      • col68
        • 1505
        The gloss varnish heips the washes run into small folds and creases and once the first wash has dried you will need to reseal with gloss until until all your washes are applied then you seal everything with matt varnish to flatten it all back
        As for washes I tend to make mine from oil paints thinned with low odour artist thinners I prefer these as you can tinker with them. The only wash I actually buy is citadels agraex earth shade which I thin with water for creating shadow on clothing and canvas items
          Going to pop to the hobby shop today and invest in some washes and some gloss and Matt varnish and give it a go. Will hopefully turn out ok, thanks for the advice
            I have been to the shop but there wasn't any citadel paints I wasn't really sure what I was looking for so I've probably bought the wrong things?[ATTACH]285760[/ATTACH][ATTACH]285761[/ATTACH]
            Will these be any good for my figures or not?
            • col68
              • 1505
              Ideally the colours you need is a dark brown for shadows artists raw umber thinned with odourless thinners would be a good wash
                How do you apply the weathering powder? I've never used any of these before. And yeah I thought I'd bought the wrong thing but I couldn't find a dark brown/dark earth shade, they had sold out. I'll have to try elsewhere next week
                • col68
                  • 1505
                  Hi jack normally I apply a coat of matt varnish to the finished figure then I use a old soft brush to apply a weathering powder or crushed artist pastel which is a similar colour to the uniform to give the figures clothing a dull finish and seal it with matt.
                  Then a dusting with a sand or dirt then a final coat of matt on top.
                    Cheers, I promise I won't drain you with any more questions now I'm just going to crack on and give them a go and see how they turn out. A lot of trial and error for me at the moment
                    • col68
                      • 1505
                      Jack its no problem mate ask away. That's the good thing about the guys on this forum. Whenever I've asked about things I wasn't sure of someone has steered me in the right direction. So I'm just repaying their kindness by passing what I've learned to you
                      • grumpa
                        • Jan 2015
                        • 6142
                        Jack, I use water based craft paints that can be purchased cheaper than dirt, no smelly thinners, just h2o. I put my figures together, fill and sand, brush paint a couple of base coats then then hit them with several coats of a blackish-brown wash of just water thinned craft paint......done
                        [ATTACH]285785[/ATTACH]
                          Hello people. I'm a beginner in this, so I still learn the basics. I wanted to ask if someone can help me. which wash you use for WW2 US infantry? Thnx.
                            I tend to just use the same wash on all my figures (citadel earth shade) it gives the uniform a dirty worn look.
                              Can I use 'Winsor & Newton' oil paints and do you know how to apply them?
