Metalic chip marks
  • Thorbrand
    • Dec 2016
    • 335
    Metalic chip marks
    Hi folks
    I'm currently building a 1:72 stuka in desert camo from the libyan campaign and im thinking about giving it a bit of a battle scarred look.
    One way i want to do this is create a metalic chip effect to mimic pieces of flak schrapnel ricoched off the aircraft. Im quite confident with burn marks and engine fumes but never created metalic chipping effect before.
    Would it be as simple as painting a metalic steel undercoat and then using some kind of abrasive device on the top finished coat to reveal the metal underneath?
    All suggestions welcome
    Should also add, im a brush painter using acrylics but planning on using my AK interactive steel paint which is oil based
  • colin m
    • 8741
    • Colin
    • Stafford, UK
    As your are using a brush, maybe a coat of aluminium, let it dry for a day or two, put your top coat on, and before it has dried, pick at it with a pin of something similar. I was going to say try the hair spray method, but scale and brushes might work against you.
      • 22770
      You could also like Colin says paint it aluminium, then let it dry then dab some maskol, or any masking fluid you've got on it. If you don't have any masking fluid try little blobs of PVA. then when that's dry paint the top colour. then when that's dry just wipe off the masking fluid, and there's your chips.
      • stillp
        • 8091
        • Pete
        • Rugby
        Or you could get a silver pencil and just stab some marks on the paint until you think you've done enough.
        • langy71
          • 1948
          • Chris
          • Nottingham
          exactly what i do when creating 'scratches'..
          • Spooky_Wookie
            • Jun 2018
            • 5
            What about a little "sponge-chipping" with silver/aluminium?
