Question about wash
    Question about wash
    i was doing a black wash on mu 1/72 U boat. sealed it with a gloss clear and honestly from the videos iv seen you put it on let it dry and wipe it off. That doesn't seem to be the case it won't wipe off with water at all. Im worried I ruined my paint job
    nyc what type of black wash did you use oil acrylic or enamel?. when I was I use very very thin layers and I only wait a few minutes then wipe off with rubbing alcohol. I use acrylics btw
    Rick
      Vallejo Black Wash. But I was using water. I messed up, I didn't gloss coat it before i did it so tomorrow I will just repaint the spot I did. thank god I only did a small area. I watched like ten videos on doing a wash and I was like why is it so easy for them to wipe it off. I didn't gloss it and I was trying to wipe it and it wouldn't come off.
      • Mr Bowcat
        SMF OG
        • Dec 2016
        • 4593
        • Bob
        • London
        Acrylic washes dry very fast, if using them you need to work quickly and in small areas. O would imagine a lot of the videos you have seen were of enamel or oil washes which can be wiped of some time later with low odour thinners or the like.
        Si vis pacem, para bellum.
        • JR
          • May 2015
          • 18273
          Erik.
          Sorry to read that, nothing worse than it going wrong at the last stage.
          Think Ricks answer with the rubbing alcohol is right to clean it off, but the gloss varnish should have gone on first , this would have sealed the paint work then you could apply the wash, when finally happy another coat of mat varnish to seal it all in.
          Think we have all been there, so don't feel bad.
          Certainly doing small areas at a time is best as the wash dries so quickly.
          Hope you manage to save the day .
          John.
            yes john I certainly lost a 1/32 dauntless to that very problem bowcat is going through.
            • Mr Bowcat
              SMF OG
              • Dec 2016
              • 4593
              • Bob
              • London
              Not me, the OP.
              I did have that exact issue in the early days, switched to oils and enamels and have never looked back.
                sorry Mr bowcat was meaning to type nyc sir.
                Rick
                • Mr Bowcat
                  SMF OG
                  • Dec 2016
                  • 4593
                  • Bob
                  • London
                  No worries Rick.
