Weathering practice, look away its not good lol
  • BattleshipBob
    • 6785
    • Bob
    • Cardiff
    Very, very rusty when it comes to weathering so had a tammy Panther so primed and added tri camo, ignore the wrong decals lol
    Applied Vallejo gloss varnish but it did not cover very well at all, more matt than gloss as its old can only think it went wonky!"! Did give it a big shake.
    Carried out a pin wash and had a go at chipping with both a sponge and brush, not happy, about 50% ok or so I think.
    Around the driver and radio guys hatches is terrible, sorry!
Name:	ebay may 19 4 012.JPG
Name:	ebay may 19 4 013.JPG
Name:	ebay may 19 4 014.JPG
Name:	ebay may 19 4 015.JPG
Name:	ebay may 19 4 016.JPG
    I sure need much more practice, would appreciate feedback, went over board in over board as as well
    Hands up, not good
  • PaulTRose
    • Jun 2013
    • 6447
    • Tattooine
    nowt wrong with that
    get some matt coat on it and it will look great
    Per Ardua
    • Bortig the Viking
      • Mar 2019
      • 780
      Doesnt look that bad to me, as commented just add a Matt coat, then hey presto.
      • BattleshipBob
        • 6785
        • Bob
        • Cardiff
        Your kind words surprise me!! Its due a matt coat (by chance new bottle arrived today) prior to first go at filters
        Thank you both
        Bob
          Looks good to me :smiling3:.
            • 18882
            Looks pretty good Bob. Only suggestion I could give is to put a spot of darker brown in the middle of some of the biggest rust chips. This will help them look a little more “3D” in nature.....
            • Si Benson
              • 3572
              Don’t be surprised Bob, looks good so far:thumb2:
              If your doing filters and washes etc everything should start to tone down and come together.
              Top tip I remember being given was to think about where chipping would occur on a vehicle like edges and corners or areas that would see a lot of crew traffic as the clambered in and out.
              The best tip I was given was ‘less is more’. Subtle, restrained weathering quite often looks better then over the top stuff
              • BattleshipBob
                • 6785
                • Bob
                • Cardiff
                Thanks Both
                I am really surprised ref the comments!
                Compared to other models it looks not to good, will try that Tim before i matt varnish
                • BattleshipBob
                  • 6785
                  • Bob
                  • Cardiff
                  Evening Si, good advice and thanks!
                  Got to practice a lot more lol
                  Bob
                    • 18882
                    Remember what Si says though, less is more.....don’t overdo it...
                    • boatman
                      • Nov 2018
                      • 14449
                      • christopher
                      • NORFOLK UK
                      :thumb2:HI Bob as the others have said it looks ok to me too so stick at it :thumb2:
                      chris
                        I'd be very happy if I could achieve that. Looks great.
                          I'd be very happy with that as well. Great work so far Bob.
                          • Steve Jones
                            • 6615
                            Chipping is an art Bob and it takes a few attempts to master. You are certainly on the right road as it is a fine first attempt. Si gave me advice when I first started and he is dead right - less is more. One small tip for sponge chipping is don't press hard with the sponge as this prevents a central blob with chips around it and instead creates smaller, more clustered chips. Also rotate the sponge as you go to avoid the same pattern of chips coming out. Any way, more importantly - that camo! Awesome work my friend. It certainly is turning into a top notch Panther. Keep up the great work mate.
                            • BattleshipBob
                              • 6785
                              • Bob
                              • Cardiff
                              Hi Tim, Si's advice well noted!
                              Thanks Chris, appreciated!
                              Hi Paintguy, very kind of you, makes a old fart happy lol
                              Thanks very much Peter, appreciated
                              Good evening Steve great advice and no doubt hard earned!!! Glad the camo looks ok, like using a airbrush.
                              I am writing up a list of what to do and when. One thing i find is not many books tell you what varnish goes with what method ie rust streaks with satin etc. Should organise my builds better!
                              I have FAQ2 which to be fair takes you right through from how to and what varnish works the best
                              Thanks again bob
