Bit embarrassed after ruining another model after spending tens of hours on it. After a bit of advice on varnish, washes and cleaning off washes, thought I’d done enough research, apparently not.
Gloss lacquer, I’ve tried experimenting with a few varnishes including pledge floor cleaner and ended it settling for alclad 2. I do find it stays soft for days though, is there a better alternative That will give a great smooth finish as this does but with a more robust finish, I can still get fingerprints 4 days after coating if pressed on hard.
Panel wash, just tried using humbrol enamel panel line which was a bit wispy washy so I probably went a bit over board. Is there a better panel line wash that flows nicely down the lines?was thinking about trying tamiya but worried about it being enamel.
Cleaning off panel wash, just tried cleaning off the humbrol panel line wash using enamel thinners and although it did clean it off, my alclad 2 lacquer has gone really soft and also rubbed off.
Any advice of what I’ve done wrong or wrong product mismatch I’m using would be greatly appreciated, I was fairly happy with how things were going but wanting to move onto panel lines and some simple weathering.
thanks Matt
thanks Matt
