Rick's BR MK1 Breakdown Support Coach weathering
  • rickoshea52
    • Dec 2011
    • 4076
    • Rick
    After trying out the chipping effect medium on my little Dauntless (nearly finished, honest) I thought I would try the technique on a coach roof. I used a limited edition model of a Breakdown Support Coach in the striking yellow with black chevrons, but it is too clean. These coaches spend a lot of time stabled outside exposed to the elements so they can sometimes look a little tatty, especially the roof.
    The first thing to do was dismantle the coach to avoid applying more masking tape than required. This coach is made by Bachmann and is quite easy to take apart.
    When this was done I masked the bodysides and sprayed the roof with Model Air Aluminium followed by the chipping effect medium where I wanted it chipped and flaked. When this was dry I used Medium Sea Grey which is lighter than the correct shade but gives that faded look. I added increasing amounts of black to the paint cup to vary the tone.
    When this was all dry the areas where chipping effect was sprayed were washed down to reveal the aluminium underneath. Next, I used Abteilung oils for the rust and dirt streaks with faded white for bird droppings. The coach has been reassembled ready for the next stage; a light dusting of dirt on the roof then it's on to the bodysides and under frame.
    [ATTACH]85710.IPB[/ATTACH]
    [ATTACH]85711.IPB[/ATTACH]
    [ATTACH]85712.IPB[/ATTACH]
    [ATTACH]85713.IPB[/ATTACH]
    [ATTACH]85714.IPB[/ATTACH]
    [ATTACH]85715.IPB[/ATTACH]
    Mmm that's a nice effect
    • monica
      • Oct 2013
      • 15169
      wow an amazing looking rust and wear effect,very well done
      • flyjoe180
        • Jan 2012
        • 12367
        • Joe
        • Earth
        A lot of seagulls out that way then
        • rickoshea52
          • Dec 2011
          • 4076
          • Rick
          I tried Mig's slimy grime effects on the roof and body sided of this coach. The photos don't show it up so well but the results are quite good. I used the lighter shade as a base and the darker shade was applied by brush for the effect of streaked mossy grime build up from extended periods in the sidings.
          [ATTACH]87729.IPB[/ATTACH]
          [ATTACH]87730.IPB[/ATTACH]
          • flyjoe180
            • Jan 2012
            • 12367
            • Joe
            • Earth
            That's looking good Rick.
