The dalpol deltic
  • peterairfix
    • Jul 2012
    • 11074
    The dalpol deltic
    I've just started on this on i thought it would be a good on to do as it's one not seen very often.I did manage to find some windows for it , as you can see the body sides need straighting i've never had one that was straight.
    The next thing was to take the extraordinary amount of flash off the body ends see the before and after pic,i have included a pic of my old which i was going to rebuild but i thougth better of it so lets see what i can make of this one
    Cheers,peter
    [ATTACH]60890.IPB[/ATTACH]
    [ATTACH]60891.IPB[/ATTACH]
    [ATTACH]60892.IPB[/ATTACH]
    [ATTACH]60893.IPB[/ATTACH]
    [ATTACH]60894.IPB[/ATTACH]
    [ATTACH]60895.IPB[/ATTACH]
    I shall watch this one, as it's something a little different.
    • peterairfix
      • Jul 2012
      • 11074
      peterairfix's dalpol deltic
      The first thing i have done is to replace the body end grills with metal ones i found some n gauge fencing that does the job quiet well.
      Cheers Peter
      [ATTACH]60915.IPB[/ATTACH]
      • peterairfix
        • Jul 2012
        • 11074
        peterairfix's dalpol deltic update
        Here is a quick update on how its going i have put the main body together and started to sand the joins also i have included a pic of the deltic that this one replaces as a comparison as my old one is a few years old and needs replacing.
        Cheers Peter
        [ATTACH]60933.IPB[/ATTACH]
        [ATTACH]60934.IPB[/ATTACH]
        [ATTACH]60935.IPB[/ATTACH]
        • peterairfix
          • Jul 2012
          • 11074
          here are a few more pics of how it is going i have now finished the body and completed one of the bogies the color is from a cheap £1 tin of r/c car spray but has done a good color.
          Cheers again peter
          [ATTACH]60977.IPB[/ATTACH]
          [ATTACH]60978.IPB[/ATTACH]
          [ATTACH]60979.IPB[/ATTACH]
          • rickoshea52
            • Dec 2011
            • 4076
            • Rick
            Hi Peter,
            My main interest is in model railways so this is an interesting thread to follow. You mentioned that you are using N gauge mesh for the nose end grills of this Deltic and I just wondered if you knew that there are numerous small suppliers that produce etched brass roof fans & grills as well as body side grills and buffer beam detail. Howes Models, 1 Stop Model Shop - Welcome to Howes Models Large Selection of Heng Long tanks, in Kidlington are a good source of these materials, including paint and transfers, and if you have a local model shop they too could give you more direction. Have a look at my blog for model railway related stuff. It's mostly weathering but some detailing stuff is there too. Ricky's Railway
            • peterairfix
              • Jul 2012
              • 11074
              thanks for your help i do have a number of good model shops in my area for this type of stuff but being in the ranks of the unenployed its all down to cost rather than choice.cheers and thanks peter
                Just a little point of interest that not everyone might know, the term Deltic refers to the engine configuration, which is triangular in shape, or loosely 'D' shaped, hence Deltic from the Greek for 'D', Delta, with a crankshaft at each corner. The corners are joined together by three cylinders, each one with two opposed pistons in it making for an extreemly compact and powerful engine arrangement. Working on one must be a nightmare!
                • rickoshea52
                  • Dec 2011
                  • 4076
                  • Rick
                  There is at least one of the later Class 55 locomotives, which is a direct cousin of the prototype Deltic, in preservation and still certified for mainline running. It spent some time last year on hire running tanker and PCA's around the North East and Scotland I believe. The prototype Deltic that you are modelling is at the National Railway Museum in York.back. The NRM produced a limited edition ready-to-run model in partnership with Bachmann a couple of years
                  • peterairfix
                    • Jul 2012
                    • 11074
                    Nearly finished just the body stripes and end whiskers to do before final assembly i have fitted windows witch don't come with this kit but are still to be found.
                    Cheers peter
                    [ATTACH]61014.IPB[/ATTACH]
                    [ATTACH]61015.IPB[/ATTACH]
                    [ATTACH]61016.IPB[/ATTACH]
                    [ATTACH]61017.IPB[/ATTACH]
                    • peterairfix
                      • Jul 2012
                      • 11074
                      peterairfix's dalpol deltic finished
                      I have now finished the deltic i've not glued the roof on as i intend to put some kind of representative engines if any one does know of any thing that would be suited let me know much beet than having a bare insides
                      Cheers peter
                      [ATTACH]61093.IPB[/ATTACH]
                      [ATTACH]61094.IPB[/ATTACH]
                      [ATTACH]61095.IPB[/ATTACH]
                      [ATTACH]61096.IPB[/ATTACH]
