Cadrail
  • John
    • Mar 2004
    • 4633
    • John
    • Halifax
    Cadrail
    Cadrail has all the extra features that will satisfy advanced users. Beginners can pick it up quickly and grow into the harder parts of railroad design. You get a rock solid, all around drawing tool for all your drawing needs. Design railroad layouts, buildings, bench work, schematics or anything else you need.
    This is a powerful CAD program with many different railroad design tools. You can create track plans of any size and shape. There are easy to use drag and drop tools that allow you to snap track sections together end-to-end and align them automatically. Flexible CAD tools let you create complex shapes that your train will run on and that you can build.
    Plan, Profile, and 3d views let you add elevations to your drawing so you can see things from any angle.
    Auto Alignment tools make it easy to snap together complex figures and shapes. Just drop one object onto another and the ends automatically come together.
    Turnout Objects (Switches) make working with yards and other complex shapes easy. Just drag and drop in a turnout. Cadrail automatically rotates it into position and cleans up any connections. An extensive set of tools is available for complex combinations of yard ladders, sidings and crossovers.
    Cadrail includes easy to use snap-together, drag and drop tools plus Hundreds of Powerful CAD tools that let you draw anything you want. Add your walls and benchwork to the drawing. Make a detailed building elevation or trestle template. Do wiring diagrams, and track schematics. Your only limited by your imagination and skill.
    Highly Accurate. When your done tweaking that yard ladder two inches to the left of that bridge foundation, you will KNOW that it's going to work and you have maximized use of the space.
    Run Trains on your drawing to get a better feel of how your trains will operate.
    Printouts to any scale. Cadrail supports ANY scale and ANY units (English, metric, etc) on any device supported by Windows. Print your whole layout or any other portion at any scale ratio you select. Print any area you select at full life size on multiple pages.
    Extensive Libraries with thousands of shapes you can use for things like layouts, buildings, bridges, scenery, track and other stuff.
    You get a full power, fully functional application with all of the famous Cadrail features. Excellent 200 page printed manual with examples. Extensive interactive computerized Help file
    Download Demo
    [ATTACH]6811.IPB[/ATTACH]
    [ATTACH]11360.IPB[/ATTACH]
    [ATTACH]11381.IPB[/ATTACH]
    [ATTACH]11414.IPB[/ATTACH]
    [ATTACH]11435.IPB[/ATTACH]
    [ATTACH]11456.IPB[/ATTACH]
    [ATTACH]12106.IPB[/ATTACH]
    www.scalemodelshop.co.uk
