A6M5 Zero type 52 1/48 Hasegawa
Posts
    I'm needing a change so this seemed a good canidate. The office was a nice fit ,not sure I nailed the color but its fine for me.
    Wheel bay and flap interior color is unique,I used some transparent blue over the green and it seems close?
    The wing to fuse fit was about 1/16 off and bending the wing tips up to seal the gap would've made the dihedral out of scale. I spread the fuse apart and tach CA 'd the cockpit floor corners to hold it,all it needed was a touch of putty on the starbord wing
    Based the fuse with ts30 silver then added some darker panels to break it up along with some white on the control surfaces
    Trying something new with shapie pens,the test panel I did had the amount of bleed thru I was looking for so giving it a go here.
    I also tried the salt method for the first time ,not so sure about it what do you all think?
    • Centurion3RTR
      • Jan 2009
      • 2093
      Trey, i think you need to keep doing the salt method mate. You've pulled it off and looks great, can't wait to see it all done.
      Have fun, John
        What's the salt method?
          • 18271
          In a nut shell:
          You paint the base colour, in Treys build the silver. when dry you spray the kit with water and sprinkle salt in the places you want the silver to show though. leave it to dry so the salt sticks and the water dries away.
          Then you spray the top colour, in this case green. When that is dry, you can then brush the salted parts off with a stiff brush and some times by rinsing under lukewarm water.
          The salt removed you get a nice flaky effect as if the top coat of paint has peeled away, or rubbed off.
            • 18271
            Tell you what Trey, that is a lot better than my first attempt! Looks good mate!
              Great work mate. The paint looks excellent. Can't tell its the first time you have used the salt method.
              Kresten
              • Andy2035
                • Aug 2011
                • 730
                Hi Trey,
                Thank you for sharing this build, it looks great...
                In a nut shell:You paint the base colour, in Treys build the silver. when dry you spray the kit with water and sprinkle salt in the places you want the silver to show though. leave it to dry so the salt sticks and the water dries away.
                Hi Ian,
                Many many thanks for sharing that, I've often wondered how people get this kind of effect...
                Andy...
                • yak face
                  • Jun 2009
                  • 13842
                  • Tony
                  Looking good trey, just the right amount of chipping, the cockpit colour looks fine to me too, and the flaps and u/c bays are good too. Its a weird colour to get right ,the aotake laquer. Ive found that a mix of 4 parts tamiya X23 clear blue,and 1 part X25 clear green is great if applied over a silver basecoat. keep it up mate , nice to see some more jap stuff, cheers tony
                    • 22771
                    Thats a cracking build so far Tray
                    • Dave W
                      • Jan 2011
                      • 4713
                      Looking good Trey.A Jap aircraft is a good subject to try the salt chipping teqnique.I've seen quite a few photo's of them with lots of paint missing.Wonder if they bothered priming their aircraft before spraying the top coat.More like it was the harsh conditions they operated in that made the paint flake off.I've heard you can get a similar effect using blobs of masking fluid.Havent tried it myself though.
                        Another visual treat i guess. LOL. Excellent detail work on the cockpit. Love to see more
                        Adrian
                          Thanks everyone really appreciate the positive support John ,Kresten,Andy,papa(Ian),Adrian,and Tony thanks for the formula ,also Ian I thank you for taking the time to field the salt technique question you explained it far better than I could lol. Dave I thought abought the liquid mask even have some on hand but wanted to take a swing at this. I might try the liquid mask on the George in my stash seems to me like you would have more control over it as the salt has a radom factor to it. Then again that random factor is the whole point of the salt is'nt it ,oh well I'm having fun either way. Not much progress to report ,did try some fast frame for the canopy as it came with the kit. The plus is you get pre cut self adhesive frame work for both sides of the canopy that do need to be painted(they come clear) and once in place do give a authentic look. The down side was that it did require some cutting down as it was too long in places and was really fiddly to work with. Dry fit looks pretty good no big gaps to deal with
                          • Andy2035
                            • Aug 2011
                            • 730
                            Hi Trey,
                            May I ask what 'Fast Frame' is please...:thinking:
                            Thank you...
                            Andy...
                            • yak face
                              • Jun 2009
                              • 13842
                              • Tony
                              Hi Trey,May I ask what 'Fast Frame' is please...:thinking:
                              Thank you...
                              Andy...
                              Me too!! Anything to make the job of painting/masking canopies easier!!!! cheers tony
