Tamiya Supermarine Spitfire Mk 1 - 1/48
Posts
  • topgazza
    • Jan 2020
    • 640
    My first proper build after the Airfix starter kit Hurricane which taught me a lot and was fun. I'll do my best to post pictures as the build progresses.
    So far I have just started assembling the fuselage cockpit area as a closed cockpit. However, I am taking care to micro paint all the tiny components even they wont be seen as such. Its good practice and very relaxing and it feels good to do everything slowly and with care. The Tamiya instructions are a bit confusing at first but read 5 times do once is a good motto. Matching colours is fun and I am using Modelshade.com to help there. I dont intend to be 100% historically accurate especially in the hidden colours. But I'll get as close as I can as a matter of principal. The Tamiya plastic feels thin at first touch but thats deceptive as boy is it well made and makes no difference to the fit. Very nice kit
    More later
  • Peej
    • Aug 2014
    • 919
    Looking forward to following the build. Good luck.
    • topgazza
      • Jan 2020
      • 640
      Spent half the day putting the seat and cockpit together. Talk about patience being a prerequisite !
      The detail in these Tamiya kits is astonishing but again, so much fun. I'm an amateur photographer but even I found it hard to get this picture right but you get the idea.
      • Peej
        • Aug 2014
        • 919
        Looking good. I'll be following this build with interest.
          Nice work Gary.
          • JR
            • May 2015
            • 18273
            Great work on the office Gary
            Will take notes.
            • topgazza
              • Jan 2020
              • 640
              The dials looked a little hidden so I dabbed a tiny touch of yellow on a couple to make them show a bit. I know Iโ€™m doing a closed cockpit but I know itโ€™s there. Anyway it adds to the enjoyment to me.
              • colin m
                • 8763
                • Colin
                • Stafford, UK
                That's a splendid looking 'office' you've built there Gary. Looking forward to the rest.
                • topgazza
                  • Jan 2020
                  • 640
                  Thanks. I have to keep resisting fiddling with it. It never looks "perfect". But fiddling is a downwards spiral so I'm moving on to fitting it in the fuselage and the no going back sticking that together.....
                  Couple more pics of this, "delicate" stage. Note the small black oxygen tank on the first pic, middle right, that was 1mm out on its location and meant the office wouldn't locate. Luckily it came off easy and I moved it. It's not 100% clear exactly where it should go. Small thing but important. If I did it again I would fit the "office" to the fuselage and then fit the tank after. Hope I'm not giving too much info.
                  Despite saying I'd stop fiddling I did retouch the uniform from its grey to a slightly darker grey/blue as per specs
                  • Komedy
                    • Jan 2020
                    • 307
                    coming along nicely
                    • topgazza
                      • Jan 2020
                      • 640
                      Wings on and bit of filler being used as you can see. Panels not quite fitting perfectly. Not bad to be fair but needed a bit of fettling. Will need to do a bit more around the base of the wings on the top as the panels dont quite level up. But thats ok. Next is to start painting the basic colours and do the camo. May use my new compressor etc for the first time. Not doing anything fancy but will try a bit of panel edging/weathering with the Flory clay wash.
Name:	Fuse Bottom.jpg
                      • Komedy
                        • Jan 2020
                        • 307
                        Filling is the bit I enjoy least
                        • topgazza
                          • Jan 2020
                          • 640
                          Oddly enough I like it
                          Maybe because I spent 18 months in a car body shop owned by a friend many years ago and used tons of the stuff and it became second nature. But its not ideal in certain areas but the Spit is not too bad.
                            • 22771
                            Looking good so far Gary.
                            • topgazza
                              • Jan 2020
                              • 640
                              Thanks.
                              I have to stick the fiddly bits and the wheels on, prop and other odds and sods. But overall I'm loving the slow, considered pace of doing this. Incredibly relaxing mistakes and all.
