GWH P61A Black Widow - 1/48
Posts
  • BarryW
    • Jul 2011
    • 6029
    This will be my first GWH build and it looks to be very promising indeed.
    First my workbench, all cleaned, restocked and ready.
    The box
    The kit sprues labelled and ready
    I might do something different and, with one kit, represent two different aircraft. Looking at it from the left it will be ‘Night Take Off’ and when you look from the right it will be ‘Cooper’s Snooper’. Purists will hate it but as you cannot see both sides at the same time and both aircraft had the same black with red trim scheme, so what! This gorgeous nose art is too good not to take advantage of it. Click image for larger version
    Etch seatbelts and canopy masks
    Tomorrow I will start cutting plastic.
  • adt70hk
    • Sep 2019
    • 10416
    I like idea of a two sided aircraft. I've seen it done fairly recently on a 1/72 Mossie.... In that case I think it was bomber/PRU combination. The finish wasn't brilliant but it was a different way of looking at it.
    Good luck with the build.
    • stillp
      • 8096
      • Pete
      • Rugby
      That's a really vicious-looking aircraft!
        • 15728
        Hi Barry
        I like your 2 in 1 plan. What does GWH stand for, I don't think I've heard of them?
          • 18925
          I’ve seen that done a couple of times in full size. B17 Sally B is/was marked up as Memphis Belle on the other side, and the Watercress line had a West Country/Battle of Britain locomotive which had Swanage on one side and Tangmere on the other. It was known as Tangage to the crews…..
          • BarryW
            • Jul 2011
            • 6029
            Originally posted by Jim R
            Hi Barry
            Great Wall Hobby was their original name but they just now market as GWH.
              • 15728
              Thanks Barry
              Now you mention it I think I have heard of them.
              • BarryW
                • Jul 2011
                • 6029
                I have made a start on the cockpit. The plastic is nice and cleanly moulded, easy quick clean up. There are a lot of very thin and fragile parts though and even getting them off the sprue is tricky. I am using a razor saw to reduce the stress placed on the part.
                Even so, some parts are just vulnerable. The ip had by four sprue attachments, two to the pedals, very tight on the sprue with little room to work on. The result is this.
                There is a hairs width of plastic attaching the pedal. As you can see one ‘leg’ twisted and snapped. I was unable to cement this back together as there is just not enough plastic. Fortunately I don’t think it will be visible so, while annoying, I will just go ahead and not have the pedal. Incidentally the instructions suggest replacing the plastic pedal with an etch one supplied anyway. A bit of a fools errand that.
                Some more pit parts. The seat legs and attachments were also very small and awkward but not impossible.
                  A bit of plastic strip behind it will probably reinforce it enough that you can glue the pedal back on, I think?
                  • BarryW
                    • Jul 2011
                    • 6029
                    This kit is almost like it was designed for 1/32 scale and downscaled to 1/48 without any considerations of practicalities. This kit is perfect if you have a very delicate touch, perfect vision and tiny hands…. I have none of those.
                    I have lost count of the number of parts I have broken, even if you get them off the sprue you need to somehow clean them up…. Most breakages I have repared, some I did not bother with as they will be behind closed hatches.
                    I am still preparing internal sub assemblies for painting so I can close up the fuselage.
                    Look at the nose wheel instructions.
                    The mudguard is attached only by a small and vulnerable piece of pe.
                    The components
                    I managed to fix the pe to the mudguard, it did take a lot of time. A lot of ca was smeered all over and needed sanding off when fixed
                    I also managed to fix it to the leg but will it survive the build? That is the question…. In the pic below the wheel is dry fitted, I will paint it soon.
                    As you can see above, it’s not the neatest of jobs but hopefully will look better under paint.
                    This will need to be fitted early in the build so it’s goi g to be very vulnerable.
                    Talking about vulnerable. I really don’t like it when companies mould aerials into a fuselage side, what are the chances of these below surviving, I am wondering whether to cut them off and replace in final fitting with brass rod.
                    I will say one thing, this model is good preparation for the Border Models Lanc as that too will have a lot of delicate parts to deal with.
                      • 18271
                      Suddenly that slightly soft plastic that Airfix use (used) is not so bad after all. Fine parts just bend a bit ant not snap if you look at them wrongly. LOL.
                      • langy71
                        • 1950
                        • Chris
                        • Nottingham
                        Originally posted by BarryW
                        ....This kit is perfect if you have a very delicate touch, perfect vision and tiny hands…. I have none of those.
                        That alone puts about 93% of us on here out of the picture....lol
                        • BarryW
                          • Jul 2011
                          • 6029
                          Ah but there is a mid point where Tamiya and a few others sit.
                          It is not just the brittleness of the plastic, it is how thin and delicate parts are, the number and thickness of sprue gates and how enclosed and tight they are grouped together.
                          • PhilJ
                            • May 2015
                            • 1145
                            Firstly Barry, very jealous of your working area, absolutely love it. Looks like this is going to be an interesting build
                            • BarryW
                              • Jul 2011
                              • 6029
                              a quickie for anyone building this.
                              If you plan to install the crew ladder in the closed position, as I do, do not fit it at this stage as you will not be able to fit the floor in the next stage. The instructions really don’t give you any good idea in what position it should go closed up. Like so many Chinese kits they cater to the ‘all hatches open’ crowd and take less notice of the rest of us.
