Merlin HC3 Airfix 1/48 Afganistan
Posts
    I got goosebumps!
    This thing will look freakin' amazing when you are done...
      • 18271
      That is really rather cool!
      very nicely done and should show all that detail off a treat!
      ps. i dont know if it is a Danish thing but the Merlin they fly over here has a rather nice gold tinge to it. It sounds odd but it looks rather nice.
      http://www.stall.dk/images/Galleri/RDAF%20Airshow/aalborg%202007/RDAF%20EH-101%20Rescue%2008.jpg shows it off rather well.
        This is cool so far the addition of the interior light looks really nice.
        scott
          Hey that is a nice colour Ian. Indulging in colours I can paint the thinging at the moment.
          Thanks to you all for the replies very nice encouragement.
          Steve calm down. Is it the air in Cagary ? ! Long way to go yet. Although I must say that I am gaining momentum, that is medium going on a bit faster, as it is getting to very interesting stages.
          Give Airfix top marks not used a spot of filler so far. Some tricky bits to come with 3 very large outer parts. But on a dry run with just a fraction of a bit of easing all looks good.
            Very good Laurie.
            One day or another I should try this.
            Francesco
              • 22771
              #66
              Great work with the lights Laurie
                Thanks Ian and Francesco.
                Going away Monday. Tut such an inconvenience.
                • monica
                  • Oct 2013
                  • 15169
                  #68
                  looking good Laurie, the detailing is great and the leds just add more to it, well done, do like the use off leds and nice chiose to use amber
                    Thanks Moni for your reply.
                      Wow what an awesome job on the Interior Laurie,and that lighting is perfect!
                        Thanks Trey hope the rest goes OK.
                          Remarkable the outer fuselage casing which are large pieces and go in 3 dimensions twisting together. Apart from a couple of very minor adjustments they fitted a good as you get.
                          Took a couple of days tacking in places to hold in areas allowing the parts to be coaxed into curved positions. Well done Airfix. That is the most complicated bit and one I expected real trouble with.
                          The tail my heart died as it looked even worse before it was all fitted together I could not believe it. Airfix should have warned. After all this could have been ultra stressful !!!!!!
                          [ATTACH]82130.IPB[/ATTACH]
                          [ATTACH]82131.IPB[/ATTACH]
                          [ATTACH]82132.IPB[/ATTACH]
                          [ATTACH]82133.IPB[/ATTACH]
                          [ATTACH]82134.IPB[/ATTACH]
                          [ATTACH]82135.IPB[/ATTACH]
                          [ATTACH]82136.IPB[/ATTACH]
                          • flyjoe180
                            • Jan 2012
                            • 12426
                            • Joe
                            • Earth
                            #73
                            Wonderful work Laurie. Most helicopters equipped with tail rotors have a slight twist in the tail boom. It is easier to angle the thrust from the tail blades than it is to build a massive blade. Have to comment in support of your initial shock though, that is one hell of an angle.
                            • Lee W
                              • Feb 2014
                              • 4654
                              • Lee
                              • Sherborne
                              #74
                              Hey Laurie, that's one awesome build you've got going on here, attention to detail is phenomenal.
                              Lee
                                Thanks for your comments Joe and Lee very much appreciated.
                                I built the Wessex and when I found this "wonky" tail I thought the Wessex does not have one. Can understand that this helps the aero dynamics on the the Merlin. It is a whopping helicopter.
                                As an aside. We had among the dynasty of five dogs over time a black labrador. We were a bit silly, living in Jersey, we acquired this lab. from Guernsey. Oh yes a wrong move this dog "Magic" (another bad move on a name) turned out to be most crack pot dog imaginable. The point. She got her tail stuck in a door that slammed and the tail is reminiscent of the Merlin's bent tail. I would add that Magic was just the funniest dog I have ever seen. We had so many laughs but then not surprising she came from Guernsey.
