Pilatus PC.24 Royal Flying Doctor Service of Australia-Scratch build from card and foam
Posts
  • wonwinglo
    • Apr 2004
    • 5410
    This model of the Pilatus PC.24 finished in Royal Flying Doctor Service of Australia was scratch built from card and builders foam salvaged from a skip,the method of construction can be used on any type of aircraft.
    Start by drawing up to the size that you want,card templates is a good way to go so save those cereal boxes they are useful
    Make up a balsa fuselage crutch from which will be the basis of adding the required shapes
    Add nose and tail sawn blocks of builders foam
    With coarse glasspaper sand the sections to shape
    Add fuselage formers
    Next add blocks on the underside of the fuselage infills between the formers
    Now fold thin card between the nose and tail formers holding in place with masking tape while the adhesive sets
    Make up the wing internal membranes from balsa sheet running a spar from root to wingtip
    Use a square barbecue stick for the wing to fuselage joiner
    The engines are made from balsa dowel,you can burn out the inlets and outlets with a soldering iron or use metal puches to get the internal shape then carve out with a knife blade
Name:	PC24 COMPLETE (20)#.JPG
    Making up the engine pods attached to the balsa membrane makes them easier to handle
Name:	PC24 COMPLETE (5)#.JPG
    Wheels are made up from rubber seals filled with two part epoxy,the seals are laid onto polythene sheet to stop them sticking to the building board
Name:	PC24 FOR RFDS (5)#.JPG
    Undercarriage legs are made from cocktail sticks and doors from folded card
Name:	PC24 FOR RFDS (9)#.JPG
    Another great model Barry :smiling3:.
    • wonwinglo
      • Apr 2004
      • 5410
      Paint is artists acrylic,for filling the foam I used Americana Triple thick brush on glaze thinned 50/50,base coat white was Blackfriers acrylic white undercoat,lettering was first painted onto tissue paper that had been treated with a thin coat of triple thick laid onto glass then peeled off when dry after the lettering was done,this was then stuck to the model with more thinned triple thick,control surfcaes were marked with an Edding 0.001 marker pen
